Question about Garmin nuvi 260W GPS Receiver
Nuvi car charger problem
My car charger was working fine, but now, when I plug it in, the unit thinks it is hooked up to a computer (that is what the screen shows.) It still charges, but I can't navigate and charge at the same time - and I could before.
    Top Expert:
  • Garmin Master
  • 78,919 Answers
The connector is defective in the GPS, this is a common problem, it must go back to Garmin dfor repair
Posted on May 28, 2010
I have garmin nuvi760 gps when ever I hook it up in my car fuse in car charger cable blown up, I changed the fuse several time ,it does the same thing,it takes 3amp 250V fuse.I realy need help.
You need to determine if it is a charger problem or a problem in the Nuvi.
If you have the AC wall charger, plug that into your Nuvi. If the unit boots normally, then you can discount that there is a problem with the Nuvi. Does the Nuvi power up on its own internal battery with the charger disconnected? When you change the fuse and it blows, is the charger plugged into the Nuvi?
Try changing the fuse and powering up the charger without it being plugged into the Nuvi. If the fuse still blows, then the fault is with the charger. Please also be aware that the charger converts +12VDC from the car battery to +5VDC to power the Nuvi. Some chargers can fail and provide +12VDC directly to the Nuvi. This can damage the Nuvi and will certainly blow the fuse.
Sep 23, 2015 | Garmin nuvi GPS
I have a Garmin Nuvi 755T. I noticed that the unit was not charging via the car charger. I checked the charger and noticed that the green light was on. I also pulled the fuse and checked it and it is...
found female jack on the 755 mount where the car charger pluges into the GPS was not securely soldered onto ckt bd so after multiple times pulg in or unpluging the unit or just stressing the connection the fine wire conncetions (about 12) tend to break forcing the unit to operate on battery mode untill battery is discharged. you an purchase a replacement GPCCradle Holder compatible with Garmin Nuvi on Amazon GPS Cradle Holder Compatible with Garmin Nuvi for about $20
Aug 26, 2011 | Garmin nuvi 755T Car GPS Receiver
My Garmin nuvi 265 was working fine until 2 weeks ago. We got a screen message saying that the XM traffic was not supported, and then noticed that the unit no longer could be charged using the car...
The traffic receiver is in the car charger cable. The charger should have a red light on if it is getting power. If the light is on and the unit is not charging and you have no traffic, the charger cable is bad. If the light is off, then either the fuse did not fix the problem, blew again, or is somehow not sitting properly in the charger. Another thing you can check is by using the unit in another vehicle. If it works fine there, then the charger is not making good contact with your vehicle outlet for some reason. You will probably have to buy a new traffic receiver charging cable.
May 04, 2017 | Garmin nuvi 265 Car GPS Receiver
I've been using after market chargers in car and on ac. They worked fine for a long time. Now, my Garmin NUVI 660 seems to turn off (goes into "charge mode" or something) when I plug my car charger into...
Yes, many aftermarket chargers are not wired the same as a Garmin charger and will cause your Nuvi to think it's connected to a PC. What happened to the original charger that plugged into the cradle (the part your Nuvi snaps into?)
Please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Jul 15, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi 350 will not run on DC charger
Make sure your DC & AC charger is a OEM charger.
There is a good chance that there is a bad connection on the mini-USB port.
What happens when you plug the unit into the cradle and NOT use the mini-USB jack?
- Jim
SHARCNET-USA
Apr 19, 2010 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Unit doesn't work with vehicle power cable
if you are using the USB cable, that won't work. You must use the bracket plug. the USB cable will charge the unit and you can't use it while it's charging. If using the USB, the system thinks you are either charging the unit or connected to a computer. This is a design flaw.
Jul 04, 2008 | Garmin nuvi 200W GPS Receiver
I have a nuvi 200 that wont run when it is hooked up to a power supply
Vehicle Power Cable to the nüvi and connect the otchapin.screen1.jpgher end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart chapin.screen2.jpg(reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
This mode will charge the battery
AND operate as a GPS.
It works with my computer USB cable, my cell phone charger and my car charger for my cell phone.
Don't forget to turn off the nüvi before unplugging."
Mar 01, 2008 | GPS
The Nuvi 200 only has a 5 hour battery. Once charged, it can be removed from the charger, but the battery will only last 5 hours. Can you plug it into the car charger and navigate while charging BEFORE the battery dies? If so, and you don't have to remove the charger, you can leave the unit plugged in while you navigate without damage to the unit.
Feb 09, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
380 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
