Question about Garmin StreetPilot 2720 GPS Receiver
Can't aquire satellites - Garmin StreetPilot 2720 GPS Receiver
    Problem Solver:
  • 4 Answers
If it is a streetpilot 2720 also may work on other models...
Turn unit off hold down menu button while turning unit on and, hold button down till a white page comes up that says general.
This this the testing mode if it is not testing then press the menu button, after test is down press menu button a couple of times and it will go to another testing, continue to the end turn power off then back on and should work it did for me.
Posted on Jun 04, 2010
Garmin 76cs will not aquire satellites after powering up
plug it into a computer and update the firmware. my TomTom has done that a couple of times.
Aug 29, 2012 | Garmin GPSMAP 76CS GPS Receiver
The dispaley states "aquiring antenna" but never finds it,can this be fixed?
Yes. However, it depends on what is causing the acquiring signal message. It could be that you just have to replace the dock or antenna. But it could also mean the unit is going bad, in which case it would need to be repaired. www.tss-radio.com has a repair guy, though with that unit being discontinued for as long as it has, he may not have parts. You may have to search around for a replacement on amazon or ebay.
Jun 01, 2012 | Sirius Satellite Radio Sirius Sportster...
Will not aquire satellites
This is a common problem on the Nuvi 3xx and 6xx series and is caused by a failed component. Please see this link for troubleshooting information.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Nov 23, 2011 | Garmin Nuvi 660 GPS Receiver
Dish Network 322 will not work both TV's at the same time. If TV1 is on it works fine, but TV2 says aquiring satellite signal. If TV2 is on it works fine, but TV1 will say aquiring satellite signal. Both...
Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
Jun 25, 2010 | DISH Network 322 DTV Receiver
Garmin 200w has trouble aquireing satellites?
Go to the Garmin dot com website and follow prompts to download the software and the firmware and software updates - they are free.
Jun 12, 2010 | Garmin nuvi 200W GPS Receiver
Easy problem to fix. Please see this link for more info:
- Jim
Nov 28, 2009 | Garmin nuvi 350 GPS Receiver
N ot able to aquire a satellite signal for two
have you downloaded the "HotFix" software update for the problem from Garmin yet? if not u will need a mini USB cable (avil on ebay for $5) and then register the GPS at this site www.mygarmin.com and select support or downloads and follow instructions..
Oct 01, 2009 | Garmin nuvi 255W GPS Receiver
I have a Nuvi 200w that I received last December as a gift. This unit takes forever to aquire a satellite. The "DIFFICULY AQUIRING SATELLITES" message comes on 90% of the times I try to use it....
While under warranty.... yes.... Make sure it's been registered on their site before calling them and requesting an RMA number.
- Jim
Sep 17, 2008 | Garmin GPS
Garmin nuvi 310 satellite aquire problem
I have a Garmin Nuvi 350. I solved the problem by purchasing a Glisson GPS antenna that plugs into the external GPS connector on the Garmin antenna.
Apr 04, 2008 | Garmin GPS
Garmin StreetPilot 2720 GPS Receiver Logo
329 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
