Question about Caloric 24 in. CDU300C Built-in Dishwasher
No water Help I have Caloric disherwasher CDU300c66B. The pump is on, but no water is coming. When you start it just hums.
  • 901 Answers
Check the incoming water to the dishwasher. If the filter is clogged clean it and re fix. Strainer is located on the machine inlet junction where the hose is fitted.
The humming sound is due to motor running without water. When you rectify the inlet flow fault, pour additional water manually into the wash chamber and run the cycle. This to remove trapped air in the pump due to dry run.
Posted on May 28, 2010
Frigidaire disherwasher leaking water
It could leak from a coupleof areas. Door gasket, door tabs at bottom of tub opening, leaking pumps. I hope it is the gaskets as they are fairly cheap if it is the pumps they are expensive but easily replaced. Good luck
May 03, 2014 | Frigidaire Dishwashers
Bendix bdw53 dishwasher pump not working?
Don't try it at home, please contact authorized service center. It may be hazardous, Please don't use it before Authorized Service Professional fixes it.
Apr 23, 2014 | Tricity Bendix 24 in. BDW53 Free-standing...
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher stops after it starts
Your dishwasher is probably draining during the wash cycle. This is usually the result of a worn out diverter valve.
Nov 20, 2009 | Washing Machines
Need a manual for Caloric model dc52151W0A
You are correct. The water sent to the DW should be from your hot water source. No need for a manual on that one!
Oct 09, 2009 | Caloric Dishwashers
3/4hp pump stalls before finally starting on 5th or 6th try.
Sounds to be a need for a new start capacitor. Have an electrician come out and chk it out.Good luck -ned-
Sep 16, 2009 | Flotec Corrosion Resistant Shallow Well...
1hp Water Ace dual jet water pump hums, doesn't pump
DOES YOUR NEW MOTOR HAVE A START CAPACITOR BUILT INSIDE OF IT TO HELP IT START. OR DOES IT REQUIRE A CAPCITOR START / RELAY BOX ABOVEGROUND. ALSO IF YOUR OLD MOTOR WAS 220V AND THE NEW ONE IS 115V YOU HAVE 2 HOT WIRES AND NO NEUTRAL. THE NEW MOTOR REQUIRES 1 HOT AND 1 NEUTRAL. HOPE THIS HELPS, JODY
Jul 18, 2009 | Plumbing
Water does not drain completely,water from sink backs up in DW
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jan 31, 2009 | Caloric 24 in. CDU510C Built-in Dishwasher
Bosch Dishwasher
Turn the water of at the inlet, diconnect hose and then reconnect it, it could be an airlock
Nov 28, 2007 | Dishwashers
Dishwashers Logo
130 people viewed this question
Top Caloric Dishwashers Experts
Are you a Caloric Dishwasher Expert? Answer questions, earn points and help others
