Question about GE Profile PDS22SBRR Stainless Steel Bottom Freezer Refrigerator
Hello I have a GE bottom mount fridge. Model PDS22SBRALSS serial AG041288 new 9/04. Fridge temp is too warm. I have found the damper closed. Compressor and both fans run. Defrost is working. I have replaced the main board. Ohmed out the sensors and checked with temperature/resistance chart they are all good. Damper did move closed and open by itself but not enough to control temp. Only moved once.If you disconnect wires to damper move damper door half open and attach wires back on the door doesn't move at all. If you leave fridge overnight the door does close sometime but will never open by it self. I saw it open by itself once when the new board was put in. Voltage to damper is anywhere from 0 VDC to .2VDC. I'm told this should be 2.3VDC standing voltage or 6VDC travelling voltage.Is this the difference from opening or closing?The resistance of the damper is 374 ohms on each side.Replaced main board second time still no better. Have been told the thermistors can be at fault even it they ohm out and also the evaporator fan can draw too much amps and damage the main board. I don't know which one to believe. I got all information from a GE service letter.
  • bogram67 May 29, 2010
    Thank you very much for your input. I do have a second part question to the same first question. Id there any relation to a evaporator fan motor drawing to much current and damaging the main board? Brian.
    Brigadier General:
  • 3,917 Answers
After going through your case its for sure that the Thermistors are the culprit. Tjhey are not holding the complete resistance for the dampers.
Please replace them and you would find that the issue would be corrected.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on May 28, 2010
  • bogram67 May 28, 2010
    Thank you for your input. I already had the sensors on order. What about this issue about the evaporator fan motor drawing too much current and damaging the main board? I don't believe in this one but I would like your opinion. By the way I have been repairing appliances for 25 years now. Thanks
GE seide by side GSS25WGPD
You will need to see if you run the self diagnostics found in the=> Service Manual The problem with the damper could be caused by a defective thermistor, ice build up or just a defective damper. Your model uses the=> WR09X10050 Damper with Thermistor Assembly Running diagnostics wil help you to locate the problem better if you can read and do the from the Service Manual. I am here if you have questions, Sea Breeze
Sep 11, 2013 | Refrigerators
GE Profile refrigerator Model PFS22SISBSS is not cooling, the digital temp control is at 74 when I try to lower it will go to 34 then immediately back to 74. The fan and freezer are both working. A repair...
The problem is damper assembly.In the damper assembly there is a door.This door opens and close with the help of motor.The damper is located between freezer and fridge section.The cold air from freezer section enters to fridge section via this damper door.---------- What repairmen did was proper, but may be that door is not properly got open, it got closed again.Or there is ice got collected between the freezer and freezer section, so this is not letting the cool air to pass from freezer to fridge.----------- ---------- This damper assembly needs to be replaced.Actually this door functions correctly with motor.He open the damper door manually and thought, the cool air will enter the fridge section non stop, but that door is again got closed, by some how.--------- You will have to get the damper assembly part replaced, to get the air flow work properly.------- As the repair man has already ordered the part, otherwise you can get this parts from online sites like www.repairclinic.com or from sears parts direct site.-------- Getting the damper door assembly, replaced will help.Thanks.Helpmech.
Sep 08, 2011 | GE Profile Stainless Bottom-Freezer...
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
I have a PFSS5PJXCSS French door with bottom freezer GE Profile refrigerator. Was making an awful noise and both fridge and freezer were warm. I opened back panel of freezer to find ice everywhere,...
Had similar problem, freezer was working fine, but fridge was warm, (68 degrees) It wasnt my damper, the mother board was fried, and so was the inverter board that told the compressor what to do, after having the inverter and two mother boards replaced.......I threw it out, biggest piece of ****, only three years old, and Sears would not stand behind it, even though I used their repairmen. I will never buy another GE product, or enter a Sears store again
Jun 03, 2011 | GE Profile PDS20SFS Bottom Freezer...
Freezer is cold, fridge is warm; replaced main board already
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 25, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Sep 25, 2009 | GE Profile PDS20MFS Bottom Freezer...
I have a brand new kenmore elit bottom mount freezer and the fridge part keeps freezing food. I have it set at the recommended settings. I have already replaced this fridge once because of the same issue....
Sep 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge warm at top cold at bottom
If the fan is no coming on inside the freezer this will need to be fixed soon. Both fans upper and lower must run while compressor runs. Inside the fresh food compartment close the damper on bottom left side next to the paned drawer. If this does not help send more cold air to the top let me know as there could be something else causing the dampers not to open and close properly.
Thanks, Sea Breeze
May 28, 2009 | GE Refrigerators
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PDS22SBRR Stainless Steel Bottom Freezer Refrigerator Logo
75 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
