Question about Insignia NS-LCD42HD-09 42 in. HD-Ready LCD TV
Color went bad it is ok for a few minuites then it goes bad
  • 4,889 Answers
That looks like a loose cable to the LCD controller. Next time it goes bad gently tap on the sides of the screen and see if the video becomes normal. If it does then its confirmed that its caused due to a loose contact. Slowly unplug the LVDS cable from the LCD controller board and plug it back in. Make sure you do not touch anything else. Also turn off the tv and unplug from the power supply before you begin.
Posted on May 28, 2010
The burner ignites then goes out in about 10 seconds then it will re-ignite in about 3-4 minuites burn for about 10 seconds then goes out. I have replaced the coils and igniter. the thermal fuses tests...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 26, 2011 | Whirlpool LGR3624JQ Gas Dryer
I have 03 Yukon Denali XL. When I drive longer than an hour on highway all of sudden all the warnig lights comes on, goes off a minuite later after 2 seconds black out. Reapeats same problem every 3 to 5...
Sounds like possibly a faulty ignition switch, They will cause symptoms very similar to that. Another thing 2001-2003s were known for are bad instrument panel clusters (dash assembly) usually the speedo gets pegged at a certain speed and stays there.
Jan 28, 2011 | 2003 GMC Yukon Denali
Wont turn on loud ossilating humming lamp light blinks for a few minuits then all three lights blink
YOU may have a bad color wheel, it is very common. The wheel will before it fails produce a loud high pitched sound and or a grinding noise.
The wheel turns at 14,000 RPM and they frequently fail.
if the wheel is shattered the set should not allow the lamp to come on (you should be able to look behind the set and see if lamp comes on for even a few seconds)
See attached photo of color wheel used in some of these sets; if it is the problem the internet not only offers them for sale but there are video and written instructions for customer replacement of this part.
If this has told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 13, 2010 | Samsung DLP HL-P5663W 56" TV
Dryer runs for few minutes and stats to get noisey
would help if knew the bran and mod#,sound's like you have a bad motor.
Nov 22, 2009 | Kitchen Ranges
Color went from normal to tecno pinks and blue polaroid TLA-04641
Turn it off unplug for 1 hour. Turn back on and time how long it takes to go bad, if it does. If the set works, then goes bad after time, you have a temperature sensitive component that's bad or will be 100% bad soon.
Mar 30, 2009 | Polaroid FLM-323B Television
Dell 2300mp projector, colors bad
try reseating the vga cable. Try removing the cable, the green tint should disappear meaning that the color or lack of one of the primary colors blue/red/green were missing due to bad connection. or maybe you have a bad vga cable.
Feb 26, 2009 | Dell 2300MP Multimedia Projector
1999 Silverado drivers side power window will not go down.
the power window motor is bad if you let it sit for a few minuites after it stops you can push the switch and it will start moving again
Jan 17, 2009 | 1999 Chevrolet Silverado 1500
Brake pedal will go all the way to the floor
make sure brake fluid is full. then pump brakes for one minuite check the fluid to see if it went down or stayed full. if it went down then check the system for a leak . if it stays full then you will need a new mastercylender . i dont think you have a vacum problem cause this causes a verry stiff brake pedal not one that goes to the floor
Dec 26, 2008 | 1993 Ford Crown Victoria
Insignia NS-LCD42HD-09 42 in. HD-Ready LCD TV Logo
124 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
