Question about ASUS P5S800-VM Motherboard
PC Not Displaying anything on Powerup
I have an ASUS P5S800-VM PC that is not displaying anything on power up. We disconnected the hard drive and still get same result. Memory modules were also removed and short beeps were experienced.
What do you suppose should we check?
Help is needed.
    Sniper:
  • 69 Answers
Check the cpu and try other memory modules or if you have more then one try them one at a time. try also reset the motherboard
Posted on May 28, 2010
MOTHERBOARD DRIVER P5S800 VM
Go to the following website to get the driver you need for your ASUS P5S800-VM Motherboard.
http://www.driverstock.com/ASUS-P5S800-VM-driver-download/6-9-10176/index.html
Jan 21, 2011 | ASUS P5S800-VM Motherboard
Need driver motherboard asus p5s800-vm
Drivers for your P5S800-VM Motherboard can be downloaded thru manufacturer's Support site:
http://support.asus.com/download/download.aspx?modelname=P5S800-VM&SLanguage=en-us
Just select the correct Operating System you are using and you're good to go.
Hope it helps.
Feb 06, 2010 | ASUS P5S800-VM Motherboard
Asus p5s800-vm MB has complete power lets monitor know
Disconnect the hard drives, cd/dvd drives and any expansion boards you have plugged into the mainboard. We want to remove as much as possible to see if we can eliminate the problem.Using the onboard video, start it up again, and see if it comes up. If it does, then its one of the items you disconnected. Power down and reattach one of the disconnected items and power up again. Did it come up? Keep in mind that we want to see the bios start up screen. Once you have attached all the items you will have found the bad component. Replace it. But lets say you didn't get a good system when you disconnected everything. Well, that narrows down the suspected bad items to: the mainboard, the power supply, the memory, or the cpu. The power supply has many voltages coming out of it, keep in mind that the drives, cd/dvd rom drives and fans use 12 volts for spin up. There are 3 other voltages used by the mainboard. I would replace the power supply next with a known good one. Then it gets a little costlier, the memory, then the cpu and then the mainboard. Stick with it. You'll find out which it is. Good Luck.
May 21, 2009 | ASUS P5S800-VM Motherboard
ASUS P5S800-VM mother board V Asus EN9500GT graphic card
you would need a new mother board or change the graphics card
Feb 11, 2009 | ASUS P5S800-VM Motherboard
I have formatted my pc. so i want to free download asus p5s800-vm
Hello safaathullah,
All the drivers for the Asus P5S800-VM motherboard can be found at Asus web site, click the link below. (All are also free).
http://support.asus.com/download/download.aspx?modelname=P5S800-VM&SLanguage=en-us (Win XP).
Enjoy safaathullah!
Any question?
Thanks for using Fixya!
Mike
Dec 06, 2008 | ASUS P5S800-VM Motherboard
I have Asus P5S800 main board
dr-afacan, You unfortunatley are not giving me a lot of info to work with. There could be several things to try. First check your cases front panel to Board connections. Then if they are correct I would swap out the power supply with anything compatible to check and see. If that PS is really OK. If you do not have the info for the board go here http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5S800-VM/e1767_p5s800-vm.pdf
Next step would be to either check the processor, possible BIOS settings or update. Or you unfortunatley just have a dead board. Asus has a good customer RMA system... Just some thoughts.....PCdok
Oct 14, 2007 | ASUS P5S800-VM Motherboard
No any display in the monitor, no beep of the RAM while CPU fan is running
Check your power supply. It sounds like you have a bad power supply. Even though the computer powers up, it does not mean that it's good. I have had this problem before, and almost 9 out of 10 times the power supply had gone bad. Just try a different one and see. hope this helps you.
Oct 01, 2007 | ASUS P5S800-VM Motherboard
ASUS P5S800-VM Motherboard Logo
339 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
