Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Alarm no longer sounds when fridge door is open
The alarm no longer sounds when the fridge door is left open, The sound icon does light up when I open the door so I believe the settings are correct. Thoughts? This is for model 79578546.803
  • 10,865 Answers
Chances are that you will have to replace the buzzer. That part is available at Sears Direct. J
Posted on May 28, 2010
  • 6 Answers
Kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Posted on Jun 14, 2010
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
How do I deactivate the open door beeper?
You can try this special mode, but it will disable the interior lights as well.
You will be required to have both the fridge & freezer doors open, and to push and hold the compartment select MODE button on the display board for 10 seconds.
When the cabinet is in this special option mode the following will not operate:
  • The interior light will not turn on when the PC door is opened.
  • There will be no set temperature lights (LEDs) displayed on the display module.
  • The door alarm will be disconnected and will not sound even if the doors were to be left open.
NOTE: When in the special option mode, the fridge icon will be illuminated, indicating that the appliance is in this mode.
To cancel, you can exit this mode at anytime by pushing and holding the compartment select MODE button for 10 seconds. If not exited manually, the refrigerator will automatically exit this mode after 80 hours.
Oct 05, 2014 | Fisher and Paykel Refrigerators
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
New integrated baumatic fridge freezer installed yesterday but the door sensor alarm keeping going off..door is def shut. As baumatic gone into administration has anyone got any ideas plse?
It's telling you it has a fault, you have to find out who is doing the warranty work for Baumatic now, by law they have to honor the warranty.
Nov 30, 2013 | Baumatic Refrigerators
Beeping & not cooling
Hi Hope, usually when the door(s) have been opened for longer than 10 minutes, an audio alarm sounds and the interior lights shut OFF. This protects the liner from melting due to the heat produced by the light bulbs. The alarm will sound every two minutes until the doors are closed. Once the doors are closed, the alarm is reset.
The refrigerator will also beep on some models to inform the user that the door has been left open and the cool air is escaping.
If the alarm keeps on going off after the doors have been closed and unit has been reset, I recommend contacting a professional technician so they can diagnose and repair your refrigerator.
Sep 10, 2012 | Frigidaire FRS3R5EMB Side by Side...
When fridge door is open start beeping sound,temperature is OK.it is same sound when door is long open
Its to warn you that you have left the fridge open its just like a little alarm so you know :)
Feb 26, 2010 | Fisher and Paykel Refrigerators
Kitchenaid KSCS25INSS
im not sure about the alarm but im going to assume its a door ajar alarm tilt the fridge back using the adjusters on the front wheels till you can open the doors about 1/4 let them go and it will close its self fridges are air tight and some times when you shut one door the air it pushes will slightly open the other the installation inst say level the unit but its better to have them leaned back the lights probably turn of auto if a door is ajar give that a try and let me know please
Feb 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
870 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
