Question about Mitsubishi WS-48311 48" Rear Projection Television
Do i need a convert box for my tv - Mitsubishi WS-48311 48" Rear Projection Television
  • 94 Answers
If your tv is not digital and you only watch tv off a tv antenna then you will need a converter box
Posted on May 28, 2010
How can I get analog channels to work with DTV without cable
Hello drandald,
Your tv is a digital tv, so you do NOT need a converter box. The tv has a built in digital tuner. But if you have any other older tv's then what you need is a converter box to convert analog signals to digital. I know there is one in Best Buy (not sure if there is one in your location) but they have one called access digital tv converter. They are about $50 (CAN). You would still need your antenna or however you get your analog signals. The antenna needs to be plugged into your converter box and then the box would need to be connected to your tv.
-Joe
Aug 29, 2011 | Zenith Z32LC2D 32 in. LCD Television
I purchased in 2000 a Sharp 13" tv model 13N-M150. I used it with rabbit ears. Is this tv cable ready? If not, do I need a converter box? Thank you.
Yes,u need a converter box to get DTV free over the air signal.The converter box is not a cable tv box,it a free DTV free over air signal box,to help the old technolgy CRT tv tube anolg tv to get Digital tv signal.All CRT(Tube Tvs) must have a converter box to get free air Digital tv.Must have pay cable tv to get a signal,if don't have coverter box.If u have a crt tube tv or u get nothing,but statics.
Apr 27, 2010 | Sharp 13N-M150 13" TV
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
Do I need digital converter box?
if you have cable or satillite than you do not need a converte box unless you have basic cable where the cable wire plugs right into the back of the tv if so a converter box will be needed to viev all chanels
Dec 03, 2008 | Symphonic ST427FF TV
Sanyo DS31590 31'' TV DO I NEED CONVERTER BOX?
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Nov 21, 2008 | Sanyo DS31590 31" TV
About a converter box
You will need a converter box for both TVs just to get the HD channels but you might not see the HD resolution on this TVs.
Any TV that was manufactured before 2002 will require the converter box. A few of the high end TVs manufactured after 2002 might not require the converter.
Hope this helps.
May 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
Need converter box
Not if you have cable TV, satellite TV, or FIOS. If so, a converter won't do anything for you. Not needed.
If, however, you only use a regular TV antenna or rabbit ears, you will need a converter box as this model TV only has an NTSC analog tuner built in.
Jan 04, 2008 | Sanyo DS24425 24" TV
Digital
Nope. Not a digital Television. I'm guessing it's an older one. Most TV's sold nowdays are Digital TV ready.
Jan 02, 2008 | RCA F32665 32" TV
Mitsubishi WS-48311 48" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
