Question about Canon imageCLASS MF5770 All-In-One Laser Printer
The printer keeps saying check the paper size when its the same paper , we have been using from a very long time
  • 2 more comments
  • Anonymous Apr 25, 2008
    exactly the same problem. i can not do nothing.
  • cools Jun 02, 2008
    yes printer keeps saying check your paper size
  • Anonymous Jun 11, 2008
    "CHECK PAPER SIZE" Canon please solve this issue fast! I will never purchase another canon product again and will advise every man and his dog to do the same.
  • anjlica_mall
    anjlica_mall Feb 17, 2013
    YEYYYYY Thankyou so much. I am so glad I found this. I am going to write these steps down. My son had so much junk in the printer and we were wasting paper.
Confirming/Deleting a Print Job
  1. Press <Status Monitor>.
  2. Press <the printer keeps saying check - la.gif> or <ra.gif> to select [PRINT], then press <Set>.
    If there is no job, [NO PRINT JOB EXIST] is displayed.
  3. If you decide tthe printer keeps saying check - la.gifte the current print job, press <la.gifcancel_printing_yesequals__noequals_.gif
    • To cancel deleting the job, press <ra.gif> for [NO].
    • Once the job is deleted, the job cannot be restored.
    • If the alarm light is flashing, open and close the front panel to reset the alarm.
Posted on Jul 10, 2008
Pls provide me a solution
Posted on Jun 27, 2008
SOURCE: have canon mf5700 says check paper size and only prints one page of several page job
Unable to clear the store with this error showing!.. There were no jobs to clear.
Well, if you unplug the power and allow the unit to discharge,(maybe overnight), the error situation clears.
Posted on Mar 18, 2008
SOURCE: paper mismatch
you have to load the printer driver for HP Deskjet 990c. This worked for me perfectly and I'm sitting here printing my wedding invites right now! Good luck!
Posted on Jun 15, 2008
SOURCE: MY CANON MF5700 PRINTER SAYS
Actionguy describes a solution where you: hit menu then # to get into service mode, scrolled to CLEAR, hit set, scroll to ALL and hit set again
You can also clear the printer's memory of the task that's causing the problem by pressing on the 'eye' button that gives the list of print/copy/fax tasks. press OK to select what kind of task you have, then choose your task to delete it. Finally press OK and Yes (minus) to clear it. Then, you can unplug the printer briefly to clear the error and it will start without the bad job and the error message.
Posted on Dec 15, 2008
SOURCE: Check paper size
Change the default setting for the paper size on your computer to letter. The paper size need to match on the printer and computer for it to work properly.
Posted on Apr 20, 2009
SOURCE: Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Posted on Feb 01, 2010
How get my WF-3640 Printer to print. It keeps saying "Paper type does not match paper settings."
Your printer comes with software used by the computer to control how it prints. Open the printer software and then select print setup. Under that screen somewhere there is paper size selection. Make sure it is set to whatever size paper you have in the printer (i.e., 8-1/2" x 11", etc.). All it is is a size paper mismatch. The computer is trying to tell the printer to print on one size of paper and the printer is saying it can because it has a different size of paper in it.
Nov 21, 2017 | PRINTER Office Equipment & Supplies
HpC309g printer keeps gaming -reason Wrong size paper but it is not
The document you are trying to print is set to a different paper size than the printer has. It is looking for paper of the correct size to be installed so it can print the document.
Aug 28, 2014 | HP Photosmart C309g Premium All-in-one...
Printer keeps saying use current size Canon MF4370DN
I am still fighting with Canon Support on this problem. They say, this is a low end printer and the feature of selecting the Match Page size option is not supported in this model.
We need to change the paper size each and everytime in each application before you go for a print.
This printer just s**ks. I am not going to order Canon printer for a life time.
Dec 09, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
My printer keep saying "
The unexpected paper size may cause the above error. Whenever your printer detects an abnormal size, this error appears on the device. It mainly happens when more than one sheet are attached with each other or when the paper trays are not set properly. To handle this issue, reload the trays with appropriate paper size followed by front and back tabs. For all the trays verify that correct paper size adjustments have been done. Now enable the jam recovery button and press the button 'GO' to print your document.
Nov 09, 2010 | Office Equipment & Supplies
Printer won't let me print or photo copy... On the screen it says " check paper size not sre how to do that...
CHECK THE PAPER SIZE ENTERED IN THE PRINTING SOFTWARE IT MAY BE OUT OF RANGE TO UR REQUIRMENT.ALOSE CHECK THE ODEL AND USE PRESCRIBED PAPER
Jul 08, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
Printer wont print. It keeps saying PC Load Legal. The printer has paper in it.
Well the printer is telling you to load "Legal Size paper, which is 8.5" X 14" paper.
More than likely, the application you are using is telling the printer to print the page on legal sized paper.
If you want the document to print on "Letter sized paper (8.5" X 11") then in the application, go to the File drop down and select "Page Setup". From within page setup's window, change the paper size to letter and then re-print the job.
Don
Dec 16, 2009 | HP LaserJet 4 plus Printer
Dell colour laser 1320c printer prints one page
in your printer properties set the paper size according to your printer paper size.
Nov 27, 2009 | Dell 1320c Laser Printer
Check paper size
Apr 13, 2009 | Canon MF3110 All-In-One Laser Printer
Printer problem
Check your paper configuration. Make sure Tray 1 is configured for Plain paper and is showing the right paper size. If it is configured for anything other than Plain Paper, most of your jobs will not print. Also, if the size says something like Univseral, then the printer is not touch that tray unless your print job also specifies Univeral as the size. If is does say Universal, check the paper guide in the tray and make sure it is pointing exactly at the paper size you are using
Dec 12, 2008 | Lexmark T642 Laser Printer
Pinting problem
First, go to the following link and scroll down to where it says "Paper sizes" to make sure the size of paper you are using is on the list. If it's not, then you will not be able to use whatever size paper you want to print on.
Product Specifications
The only other thing you can do that I can think of is to go to the following link and then click on "Set paper size". You may be able to set your printer to accept the size of paper you want to use:
Printing Overview
Good luck.
Sep 12, 2008 | HP PSC 1610 All-In-One InkJet Printer
Canon imageCLASS MF5770 All-In-One Laser Printer Logo
816 people viewed this question
old marine
old marine
