Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Sony HS30 Convergance Issue
I need some specific information please.
1. Exactly where are the STK's located on the board chassis?
2. Where do I buy replacements?
3. Will the whole board chassis have to be removed to replace them?
4. If the resistors are bad, how many, exactly normally goes bad?
Thank you,
John
  • pede69 Apr 07, 2008
    Thank you very much...
    That was a big help.
    John
  • pede69 Apr 10, 2008
    After looking at the resistors, I can not find any that look bad. I think I should be looking at the 1/4 watt ones. There are also some, like, 1 watt ones. They look ok as well.
    Have not taken the D board out yet.
    How should I approach this resistor issue? Should I order a couple just to be safe. Or just order the STK's or what do you think exactly?
    Thank you so much,
    John
  • Sony Master
  • 8,617 Answers
The STK ICs are located on the D board their locations are IC801 and IC 802 they are both STK392-560 and you will only have to remove the D board. Usually only 1 or 2 resistors go bad right next to the ICs heatsink. You can get replacements at the following link and they include installation instruction plus free tech support heres the link.
http://servicemanuals.vstore.ca/
Posted on Apr 07, 2008
  • Sonny Berry
    Sonny Berry Apr 08, 2008
    youre welcome. let me know if you need any more assistance.
  • Sonny Berry
    Sonny Berry Apr 10, 2008
    Your model usually will be fine if the resistors are not discolored . I would suggest ordering the new ICs . You can also to be safe order a couple of convergence resistors also as they are all the same price and they confirm your order they will let you know the resistors that are in your model and request you to select which ones you want them to ship. You can also email them before placing your order and they will tell you which ones are in the covergence circuits for your model.
SOURCE:
When you push the main power button on and the standby button it turns green for 2 seconds then turns right back to red what's going on???
1 or 2 things, Blowed Fuse on the Deflection power supply board
6.3 amps will be located in the Middle of chassis.
STK ICs need to be replaced STK392-110 use 120s
Mats Electronics has them 1-800-628-1118
Oct 31, 2010 | Pioneer PRO-700HD 64" Rear Projection...
I have a sony projection tv model #KP51WS510 and I was told the convergance amplifier was going out and I was needing info about where it is located so I can change it out. Thanks
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 24, 2009 | Sony KP-51WS510 51" Rear Projection...
Blinking green light of death on Mit WS55513. Changed the four 1000uf (35) capacitors on the DM board and it still won't work. Nothing has changed. Any help? Thankyou, [email protected]
THEY are green and look like 1/2 watt resistor but will have amperage marked on them and the board--there at least 2 of them near the caps--if you need a photo of what they look like [email protected] chips will not cause the set to not boot up (the green light blinks and does not stop)
I do this here for free so if this information was helpful give me a vote here--good luck---if you cannot fix the receiver the only choice is to contact PTS electronics--you can ship it to them for repair/rebuild---part no longer is available from MITSUBISHI.
REGARDS, SD TECH
Sep 13, 2009 | Mitsubishi WS-55513 55" Rear Projection...
I need a convergance chip but don't know where to get it
I learned today on my Mitsubishi VS-60621 (chassis VZ4) there are 3 convergence ICs (3, not just one as previously suggested), all 3 are STK391-020 located underneath the large heat sink on the upper right (as viewed from back of set), above the large PCB with the 6"x10" cover in the middle. The 3 chips are hanging upside down from their heat sink, have aluminum covers over them (so well hidden, it took me hours to find them, not knowing where to look), and the whole heat sink & chip assembly comes out by removing 2 screws, the front one must be accessed by removing the large lower front plastic cover and fiber-board piece behind it. Not necessary to remove the smaller plastic cover and control box above the big one. The big plastic cover has 2 large tabs on the bottom straddling the center post that will still hold it on once the screws are removed, gently pull down on them to release it. Not necessary to remove the glass doors, but probably safer to do so. Good luck!
Aug 27, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Sony kp-57ws510 convergenece prblem
You didnt replace the STK's? You must replace the convergance IC's or you will continue to have this problem.
Sep 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Convergance chip
Thats the regulator chip for the convergence circuits thats the one youre most likely needing, as your chassis doesnt have convergence ICs. You can get that IC at the following link and they will provide free installation instructions and free on line tech support just in case you need assistance. Here is the link.
Apr 23, 2008 | GE 46GW947 46" Rear Projection Television
GE 46GW947 BOWED PIC
the manual is almost impossible to find. But that chassis usually only has 1 IC that powers the convergence. Usually a STK730-020 or simallar. post the number off the IC you see up front and I will cross reference it for you and post a link where you can get a replacement
Apr 22, 2008 | GE 46GW947 46" Rear Projection Television
Hi Slinterio...
John the resistors for your model are all 4.7ohm most are 1/2 watt the other few are 1/16 watt but they are all 4.7ohm rated flameproof.
Apr 10, 2008 | Sony KP-46WT500 46" Rear Projection...
Convergance circuit board
you don't need a convergence board the one you have could be fix the only problem is the alignment is not that easy and won't cost $ 500 unless you live in alaska and worth fixing it today you just get bad set made in chi???
Nov 25, 2007 | Sony KP-53HS30 53" Rear Projection...
Convergence PCB probably not available....can you get me any #'s off the PCB or part # of STK IC or location # of convergence IC ??? ..................Should be worth fixing if I can get alittle more info....................T.
Note to mountain mom: You have a completely different
symptom ..............+ need service #.............
Try DVD ? all inputs ? cable box ? source to RF coax= on ch.3 ?..............................T.
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
