Question about Acer Computers & Internet
My acer does not have a slot for disks. how do i reboot it?
Do you do an acer reboot disk for an acer aspire 5733?
You can download Windows OS discs from Microsoft for free, use your COA to register it.
Jul 13, 2014 | Computers & Internet
It wont reboot, keeps asking for reboot disk for which i dont have because it was a gift
Reboot means restarting the pc after a simple power off - so there is no reboot disk.
If you are referring to recovery or reinstall disk then you can order a new one from Acer - for that go here
https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
Aug 16, 2011 | Acer Aspire 5330-2339 Notebook
Getting disk error error but i have no disk to reboot my acer 4520 is there another way
Google "getting into the bios of an acer aspire" and it will have different ways in trying to reboot. Try that and see what happens. If that doesn't work, then come back and then someone will figure something else to do for you. OK?.
Jul 06, 2011 | Acer Aspire 4520-5582 Notebook
For Acer Aspire One Net Book Check cable connection..! PXE-MOF: Exiting Intel PXE ROM No bootable devise-- insert boot disk and press any key
Your netbook is trying to boot from your Lan/Ethernet connection since It can find no working hard drive to boot from. This usually means that your hard drive has failed.
Also remember that your netbook will try to boot from other drive types including your SD card, USB Memory Stick and even a Magic Jack if you have one inserted in the flash memory slot or USB slot while rebooting the PC.
Many people have mistakenly assumed that their Netbook is messed up because they forget to remove all flash and memory sticks before rebooting.
Oct 31, 2010 | Acer Aspire One PC Notebook
CD-RW/DVD drive doesn't detect disk on Acer 2930z laptop
may be your combo drive go to demage change it replace another or you use external usb cd rom or DVD must be select usb cd rom/DVD
Nov 23, 2009 | Acer Aspire 2930-4661 Notebook
Trying to put a recovery disk on my pc for the acer aspire one. problem is my pc is not taking this disk i have tryed rebooting from the cd but nothing can anyone help please
Is the system running MS Vista? I had this problem with a PC the other day. What I ended up doing was using an XP disk to format the HDD, then before I rebooted I ejected the XP disk and insterted the recovery disk. When the system rebooted, THEN it booted from the recovery disk.
Oct 05, 2009 | Acer Aspire One A150-1006 Notebook
My acer will only boot to the Microsoft Windows loading page then it starts over. How can I reboot my acer without a disc?
Enable disk-to-disk recovery
On boot, press <F2> to enter BIOS. To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility, then select Main from the categories listed at the top of the screen. Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled. Save and reboot. While the Acer logo is showing, press <Alt> + <F10> at the same time to enter the recovery process. Refer to the onscreen instructions to perform system recovery.
Oct 05, 2009 | Acer Aspire 5100 Notebook
How do i reboot without a disk
do you mean format your system
if so check my computer see if you have recovery in there
or check my computer c:\ drive
you should have a folder that says Acer recovery should be in there
Jan 28, 2009 | Acer Aspire 5610-4648 Notebook
Windows will not boot
Just turn-off network boot in your bios
Nov 15, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
