Question about Peak Performance Peak PKC0AM 100 Watt Power Inverter With Swivel Neck
What size fuse goes in this item - Peak Performance Peak PKC0AM 100 Watt Power Inverter With Swivel Neck
    Brigadier General:
  • 4,090 Answers
The fuse you wilkl need to p-0rotect this unit is rated at 50amps
Please rate my help++++Thanks for using FIXYA
Posted on May 28, 2010
I need to know what size fuse goes in the fuse panel in the # 17 space
look in the owners manual.it will tell you the sizes for all the fuses.
Jul 10, 2009 | 2002 Ford Ranger Regular Cab
I have different amps in the fuse box, and the little card that I have shows pictures of what the fuse is for, but the pictures arent clear as to what they are actually for. There is nothing in the owners...
if your car in not equiped with these items they will not have no fuse, is everything working ok? If you need to replace just replace with same size fuse. allways ok to go biger the it ask for just not smaller amp.. good luck to you i don't thik i help you much.
Mar 27, 2011 | Volkswagen Beetle Cars & Trucks
Fuse amp size for 32" bush iD
If you mean the mains input fuse then usually 3.15A Fast Blow.
Other fuses vary.
Dec 24, 2010 | Bush 5693D 24" TV
Power mirrors, clock and cigarette lighter won't work
Get your owners manual out and go to the page with fuses and the diagram, look for the fuse marked with one of these items , sometimes there will be multiple equipment packages on the same circuit so when one fuse goes several items quit working ..
good luck
Nov 19, 2010 | 1998 Toyota Camry
Replacing fuse on 2001 Honda Civic Instrument panel
Use fuse size listed on fuse panel, panel should show diagram and fuse sizes. Putting a larger fuse where it does not belong could result in melted wires.
Feb 16, 2010 | 2001 Honda Civic
What size fuse goes in position #4? What are
From the Jeep TJ Wrangler 2004 - Owners Manual (Section 7, Page 255):
Fuse 4 -->> 10 Amp Red -->> Door Switch Defeat
Fuse 16 -->> 10 Amp Red -->> Headlamp Aim (Export only)
Fuse 20 -->> 20 Amp Yellow -->> Transmission: Manual - Clutch Interlock switch by-pass Automatic - Ignition Starter Circuit
I really hope helps with this (remember rated this help). Good luck.
Dec 16, 2009 | 2003 Jeep Wrangler
1992 fuse pannel
If your fuse panel has a cover it will have a diagram on it telling you what size and what each fuse does, The fuse panel will be labled telling you what size fuse goes in each spot and what it is for.
Oct 02, 2008 | 1992 Cadillac DeVille
Peak Performance Peak PKC0AM 100 Watt Power Inverter With Swivel Neck Logo
Top Peak Performance Electronics - Others Experts
Are you a Peak Performance Electronics - Other Expert? Answer questions, earn points and help others
