Question about Compaq Presario 5000 PC Desktop
I have no monitor what so ever...i hear the fan running on my tower and i have the power light...i bought a new video card and cords but i cant see to install the video card what do i do or what did i do wrong...it ran a virus scan the night before and defragged that night woke up to a black screen
  • Techno City
    Techno City May 28, 2010
    have you tried it with any other monitors ! also you can remove the new card you bought try it on basic avilable card swith will be attached to motherboard
  • 428 Answers
Clean the connectors of the monitor cable. Clean your RAM and check the disk. Most probably a cable fault. If you see the Hard Disc indicator while booting then no problem with the disk (since you get no error messages).
Please rate the answer if it solves the problem. Thank you for contacting Fixya.
Posted on May 28, 2010
Have an xps 200, monitor suddenly went black the other day in the middle of use. Noticed the power light had gone from green to amber. When I push button on monitor says it is in power save mode, to move...
Try connecting the monitor to a friend's computer. If you get some sort of a display it's not the problem. When you say that the computer makes a new noise like the fans are spinning fast, you might have an issue with the video card , motherboard, or power supply.
Aug 05, 2013 | Dell XPS 200 PC Desktop
My monitor no display and light is blinking
if the monitor light is blinking this suggests that, there is no display signal coming from the tower. This could be because of the following .
1. Bad video card 2. Bad video software
To check,where the problem is , power of the system tower and remove the power cord from the back of the tower. Press and hold the power buttoon for 10 seconds and the reconnect the power cord and turn the tower on. Check if there is any display or the status of the light changes from amber to green for even a small instance.
If the light changes to green and back to amber the video port on the tower is bad
Alternatively you can connect the monitor to another desktop or laptop to check if the same is working correctly.
Thanks for using fixya
Proton
Oct 13, 2012 | Computers & Internet
My emachine desktop tower will not power on
the sound you are hearing or heard could have been power surging through a powersupply unit that just blew.. hopfully it did not effect any of the other hardware..to trouble shoot this you can do one of two things..1 disconnect the 20/24 pin powerconnector from the motherboard 2 disconnect the cpu power connector 3 disconnect the 6pin power connector from the graphics card if there is one some machines have onboard video chipsets if thats the case then no worries 4 disconnect the Harddrive power 5 jump the power supply to see if you get any power from it any questions on that go to youtube and type in how to jump a power supply... or option 2 is buy a new power supply make sure its 80plus certified and replace it...i know its a lot of work but i hope this has helped you
Aug 26, 2012 | E-Machines eMachines Desktop PC
Pet pulled out power supply cord and now tower won't work
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 04, 2012 | HP Computers & Internet
Black screen no cursor no keyboard use
When you powered on the machine did you hear any beeps, hear the fan running, the disk drive running, lights blinking, hear the cd drive click, see the light on the cd drive door for a second or two when it clicks? If these things are happening you are getting power. If not, your problem might be with your power supply, hard drive or motherboard. Remove the power cord, then press and hold the power button for 30 seconds, then plug it back in and press the power button. if it boots you had a static charge. If you get nothing at all but a silent system your power supply is bad. If it sounds like your computer is running but you can't see anything on the screen you might have a problem with your screen or video card. If you have another monitor try using it and see what happens. if it works so you can see things then your monitor was bad. If it does not work with another monitor but you still hear fans, and see lights and hear the disk drive spinning, then your video card is probably bad.
Mar 17, 2012 | Gateway Computers & Internet
When I turn the computer on it goes into digital power save and windows does not load
The monitor is going into power-save mode because it's not receiving a video signal from your computer. Are you turning on the computer at the monitor or on the tower? If you're turning the tower on are you hearing any noise (i.e. fans running, beeps, drives spinning, etc.)? Does the power light on the tower come on and stay on? If not you may have a bad power supply or other hardware issue.
May 02, 2011 | Computers & Internet
My desktop will not turn on. Monitor shows no input. Fan in tower running very high. No lights on the tower.
In this case if you monitor say no input or no signal it means the monitor connector cord are not connected properly to the motherboard. Or if you have a video card you need to plug your monitor connector to the video card. Because if you a video card and the monitor cord are connected to the motherboard the monitor will not be display. So check the monitor connector if it is correctly connected.
Regards
nicole
Oct 03, 2009 | Computers & Internet
E machine t2482
Try changeing the RAM and if that dosent work try the processor
Jun 02, 2009 | E-Machines eMachines Desktop PC
My emachine desktop is not not coming on
I've owned nothing but e-machines towers for probably 9yrs. I've had this exact problem with two of them already. E-machines are notoriously known for power supply problems (which is usually about a $50 fix), but oddly enough the two problems I've ever had with the tower not powering up, resulted in being a problem with the motherboard. You can order another one, but it's VERY costly. Odds are that your info is still perfectly intact on your harddrive. When I experienced this problem, I removed the harddrive and installed it as a backup drive within a new tower. (I know you probably ask 'why keep buying them', but in my opinion, Gateway does a REALLY good job of keeping their "e-machines line" with up-to-date features and it's definitely hard to beat the low price!)
If you still have a perfectly functioning monitor, keyboard, mouse, printer, etc, you may want to consider buying just a new tower (approx $250-$400 depending on brands)
Oct 22, 2007 | E-Machines eMachines Desktop PC
Emachine W1135
when ur starting the tower and it light are on and ur fan there is no problem with the power supply, i think that u rily need a new motherboard because ur board will not boot on start up..
Oct 17, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
Compaq Presario 5000 PC Desktop Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
