Question about Vintage Keeper chillR 900
Looking for an evap coil for a chillr-900 wine room cooler made by either Drobot or Whisperkool serial # ap9-06088-075. Did a leak check as unit was out of freon so my tech pressurized system to 100 psi and found oil residue in evap drain pan but no alarms, can you help me find a distributor to purchase the evap coil? My name is Rose with Central Heat and Air in Sonora, Ca 209-532-7132. Thank you
3 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: VP500 Cooling unit issues
http://www.rosehillwinecellars.com/3rsV2/54_RHWC_plans/tuscany_plus_250_500.pdf
above is a link to the Vintage Keeper manual PDF format manual and problems and trouble shooting guide
Posted on Oct 23, 2007
pride applia
  • 232 Answers
SOURCE: Koolspace NUVO wine cooler recharge
do you have a recovery machine and gauges you need to tap both sides to check the high to and it needs to be vaccumed down to remove moisture ,find and fix the leak. leaks arnt verry common un less someone broke a line somehow. if the compressor is running it is more likley it has a restriction or bad valve in compressor, hooking to high and low sides will determine which if is less than 5 years old it could be under warrant still most sealed systems have a longer warranty than the rest of it is the evaperator getting cold at all.
Posted on Dec 31, 2009
My wine cooler is making a loud humming noise. It still cools fine, but you can hear it throughout the house now.
possibly the compressor is running harder due to either being low on freon or the condensor coils are dirty not letting the heat to be released causing the the compressor itself to overheat.
Sep 05, 2012 | Vinotheque Whisperkool 3000 Wine Cooling...
The unit ices and only cools to 65 rather than the 55 degrees that is set
Have you cleaned the condenser coils ? Is the unit too close to the wall ?
Dec 17, 2010 | Vinotheque Whisperkool 3000 Wine Cooling...
The Whisperkool 4200 unit is no longer cooling the wine room. The digital display is jumbled and will not reset when unplugged. The fan runs constantly but the wine room is only be cooled to 64 degrees. I...
Version:1.0 StartHTML:0000000149 EndHTML:0000001329 StartFragment:0000000199 EndFragment:0000001295 StartSelection:0000000199 EndSelection:0000001295 All WhisperKOOL units come with a 2 year parts and labor warranty with a 5 year warranty on the compressor. During the warranty period, if the unit fails a replacement unit is sent at no cost to you. If your unit fails after this period we offer a Consumer Care Program to give the customer a chance to get a new unit at a deep discount. In many cases, the failing unit has been misapplied and the correct unit for the installation is sought after during the replacement process. Our customer service department is trained extensively, with live customer service representation with a streamlined process for not only helping with the products, but also assisting in identifying any limitations to the installation or ventilation of the cooling unit.
If a repairing the unit is the decided route, call WhisperKOOL directly at 1-800-343-9463 and parts can be ordered depending on availability. A knowledgeable HVAC Professional should perform any repairs due to the refrigeration system.
Jun 30, 2010 | Vinotheque Whisperkool 4200 Wine Cooling...
Nobody has answered my question!
check freon and fan motor and maybe your thermostat
Mar 02, 2010 | Vinotheque Whisperkool 4200 Wine Cooling...
Whisperkool 4200 icing up
Hi, Bob:
Misery loves company, so I'm posting this even if it isn't in time to help you.
I had an XLT 8000 with similar problems. Vinotheque wanted to do the exchange program ($2,500+), and I was told the older aluminum coils might have leaked, and the exchange models come w/ SS coils. I was near to biting on that, when I decided to have a local refrigeration shop check it out.
Here's what they found--A MANUFACTURING DEFECT. It seems there are small copper capillary tubes that circulate the refrigerant. If they touch each other, with normal operating vibration they can wear holes in each other and the refrigerant can leak out. The leak can be very slow. According to the guy who fixed it (all for $219, and much of that was for drilling out the riveted-closed enclosure), "crossed cap tubes" is a Bush League mistake, akin to not putting oil in your car's crankcase.
I'm not saying WhisperKOOL/Vinotheque did this on purpose, knowing there would be an eventual failure and an opportunity to make another sale. But what the service guy told me was that IF the manufacturer was without scruples, a crossed cap tube would be the perfect way to take advantage of an unsuspecting customer.
My fix? Drill out the rivets, and find a local qualified service tech. Fixed in hours for $219 or in weeks with an exchange for $2,500... You choose.
Sep 25, 2009 | Vinotheque Whisperkool 4200 Wine Cooling...
Ice is forming on the outlet holes on the face of my 4200 xlt
you should check to see if the fan at the back of the unit is operating, and you also need to check for dust build up, if the fan is working then clean and defrost the unit, try it again, make sure there is nothing blocking the airflow, if the motor is not running, replace the motor, hope that helps
Jan 18, 2009 | Vinotheque Whisperkool 4200 Wine Cooling...
Cool air outlets frozen over with ice
And the temperature hasn't changed at all (still set at 55ºF)? A troubleshooting guide says you can check if the cause is because too much heat was lost to adjacent areas, and you can try to add more insulation around the ductwork and ensure doorways and glass panels are sealed. Other than that... not sure. If it's older, maybe you can look into a new Whisperkool split system or cooling system (there's some great ones on http://www.vintagecellars.com).
Jan 02, 2009 | Vinotheque Whisperkool 3000 Wine Cooling...
Vintage Keeper chillR 900 Logo
49 people viewed this question
Top Vintage Keeper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
