Question about Craftsman Garden
I've got an old model 917.255736 11 hp 38" cut hard to shift
I've got an old model 917.255736 11 hp 38" cut. It is a great mower but it is very hard to shift from reverse to forward. Once in forward gears it shifts effortlessly from one gear to another. What are the 2 screws for on the front of the transaxle? one is down all the way and the other is sticking up. Could this be the problem? Thanks for any help.
  • 6 Answers
SOURCE: Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Posted on Apr 22, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
mowerman1857
  • 389 Answers
SOURCE: I need a belt diagram for a Sears Craftsman II 12
Go to the above address, type in your model number
917.257280 just like this with a dot not a dash it will locate the tractor for you, go to the list on the left side of the page and select >>38" mower<< at the bottom of the Sub-components list and it will show you a picture of how it looks installed as well as all associated parts
Posted on Oct 03, 2009
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
wadembly
  • 475 Answers
SOURCE: Bolens clutch wont engage
check to see if there is something caught around the blades that won't allow to turn
Posted on Jun 27, 2010
I have a poulan 38" mower. Something seems to be wrong with the deck. The left side cuts great, but not the right. The right side seems to beat the grass into submission. If I back up over the same path I...
check mower blades for blade upside down. you may be hitting grass with back of blade. match blade position to working blade side. or swap blades left to right and see if problem moves. if so, blade is culprit. also cold be a loose blade bolt allowing the shaft to spin without driving the blade. Do all work with engine off key out!
May 16, 2013 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Bolens belt
if you hit something that hard you my have damaged the spindel housing
May 05, 2013 | Mtd Garden
Engine stops when I engage attachment,or travel clutch. I know it is electical but can not find the cause. Can someone Help? Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed...
Have a Poulan 27147 model 13.5 38"
Start the mower and release the clutch or brake whichever you call it and the mower will stop. Have replaced the switch and soleniod and it still stalls out. Any solution to this? Been looking for a manual for this model - only 10 yrs old - but no luck.
Jun 23, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Apr 27, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan 38" 15.5 hp lawn mower cuts off when blades engaged.
you have a bad blad saftey swich that all it is replace that and youll be good to go
Oct 01, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Mower mows graet for 30 mins then starts to load
Yes you need to replace the needle and set in the carb.
Aug 23, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a Yardman 12.5hp 38&quot;in cut mower.
you might want to get a book on this mower spring are fasen all kind of ways its hard to tell how to do it with out look at it
Jul 20, 2009 | Garden
Describe your Poulan 38-Inch Steel Deck 15.5 HP
Go to this site:
http://www.mowerpartsweb.com/manualindexasp.asp?manu=POULAN&Submit2=Submit
Download the manual and it gives a good clear picture of how the belt is supposed to go on.
Jul 17, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
95 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
