Question about Toro Lawn Mower With Toro Power Tools
Show me a picture of replacing starter rope for Toro model 20027 lawn mower. Serial number: 200008775
5 Suggested Answers
  • 86 Answers
SOURCE: Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
Posted on May 16, 2009
connertamago
  • 37 Answers
SOURCE: mower will not stay running
im not good with toro products but i believe that whatever mechanism pumps fuel into cylinder has failed. you would have to keep priming it to keep it running, basically. that's all i know about toro but having the carb replaced should do the trick and if not the the engine is shot.
Posted on Jun 01, 2009
mowerman1857
  • 389 Answers
SOURCE: the starter rope broke on my Toro mower and the
I cannot believe that someone suggested grinding off the rivets. If the bottom portion of the rivet falls down and gets caught by the magnet on your flywheel and you try to start it you are going to do some SERIOUS damage.
Here is the instructions DIRECT FROM BRIGGS & STRATTON:
This is a relatively simple process, but you have to be VERY careful when doing this. The spring is long, under some tension and has sharp edges. Anytime you are dealing with the manual rewind starter assembly, there is risk of the spring coming out and possibly injuring yourself or others. If you do not feel comfortable performing this repair, I strongly suggest visiting one of our many authorized dealers in your area and have them do this for you.
You will have to remove the gas tank2.gif to get at the rewind and blower housing. Remove the entire blower housing and rewind assembly and turn it upside down.
NOTE:You do not have to drill out the rivets to get to the back of the rewind assembly. This is only necessary if you are removing the ENTIRE rewind assembly, (metal housing and all) and are separating it from the blower housing.
You'll need a pair of vise grips or a screw driver, some rewind rope, a long thin sharp tip flexible object (the wire from a coat hanger may work) and a lighter handy.
  1. Take the pulley and start to turn it so that the rope becomes loose.
  2. Remove the rope.
  3. Once the pulley is all the way out, with the most tension, either use the screwdriver between the spokes of the pulley, or use the vise grips to hold the pulley in place; be careful not to place too much pressure on the vise grips, the plastic pulley may break!
  4. Make sure that the hole in the pulley lines up with the hole on the rewind assembly.
  5. Using the wire from the coat hanger, push the rope through the hole of the rewind and pulley. Pull the rope through the pulley and tie it off. Now use the lighter to burn the end of the rope to prevent the not from coming off.
  6. Now, remove the screwdriver or vise grips, while holding on to the pulley.
  7. SLOWLY let go of the pulley and the rope should feed back into the pulley as you do this.
Posted on Sep 18, 2009
kel1guy2002
  • 3740 Answers
SOURCE: starter rope broke how do i replace it
You have to remove the whole engine air shroud over the flywheel to gain access to the recoil and rope mechanism. If you need specific help on your exact model engine I need all of engine model type numbers 5 to 6 char then 4 char then 2 char i.e XXXXXX-YYYY-ZZ for B & S Honda numbers are by the engine oil port on the base of the crank case. Thanks for using FixYa, Kelly
Posted on Apr 23, 2010
HOW TO FIX MY TORO RECOIL
You need to probably replace or put the recoil spring back in place.,You have to take the recoil off to do it.
Jun 22, 2014 | Toro Power Lawn Mower
How is the traction cable adjusted on Toro Model 20027, Serial # 20005663. I'm replacing the cable and the new one is slightly different from the old one, but the Toro shop tells me it's the proper...
There is a large black plastic nut at the end where the cable attaches to the mower transmission. Turning it clockwise tightens the cable (engaging traction bar is tighter) and counter-clockwise is loosening the drive. If the cable is a little too long, you have to tighten it more.
Sep 27, 2017 | Toro Power Lawn Mower
Toro super recycler
Push primer bulb at least 3 times. Pull starter rope until it starts. Ensure safety lever is engaged on handle.
Aug 02, 2013 | Garden
Toro walk behind model 20016. The starter rope did not break it just won't pull out??? HELP
Remove the rope case and see if it is the mower -also - remove the spark plug and try it - also - - after removing the spark plug - also -try spinning the blade. If you remove the top you will see the problem sooner.
Gary @ Fix Ya
Sep 09, 2010 | Toro Lawn Mower With Toro Power Tools
Need the engine model number for toro mower model 2006,serial 270001124
I too was looking for the engine model number and serial number for my Toro mower to submit a claim for a class action suit. I could only find the "Mower" model and serial number. I found a guide to locate the engine information in the "Engine Service Manual" for my mower.To get the "Engine Service Manual", I went to Toro's website https://lookup3.toro.com/request/request.cfm and entered the "Mower" Model # and Serial Number. That brought me to a speific page for my mower with several manuals listed, including he "Engine Service Manual" which could be downloaded for free. The information for locating the Engine Model and Serial Number was found on the first page of the Preface. Here is a sample link for my mower Engine Manual https://lookup3.toro.com/request/filechek.cfm?Lang=EN&PubNum=492-4202&PubID=6924&Cust=anonymous_user&xCaller=Toro&PubType=9
Apr 26, 2010 | Toro Lawn Mower With Toro Power Tools
Starter rope broke how do i replace it. toro super recycler mower. Removed the plastic engine cover and the recoil mechanism seems to be rivited down and I cant get in there to replace the rope. Please...
Apr 22, 2010 | Toro Lawn Mower With Toro Power Tools
Doesn,t engage with engine
sounds like the dogs and or springs are worn.When you had the cover off the machine did you check that the dogs would freely move out when the rope was pulled? They some times stick and will not engage.
Dec 26, 2009 | Toro Garden
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Starter Rope Rewind Problem
I need to replace rope on my lawnmower starter, are there any tips on this?
Dec 11, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
104 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
