Question about HP Photosmart D7160 InkJet Printer
Ink system failure, how do I reset the printer
HP Photosmart D7160 printer error, ink system failure, how do I reset the printer error log
  • HP Master
  • 1,684 Answers
The ink system failure is caused by air in the ink feed tubes. This happens if you allow the ink to fully run out of the cartridge and it **** air in or if you use poorly filled refill cartridges that have air bubbles. To clear the error you will need to perform a purge on the ink lines to clear the air out. We have a step by step guide posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ The process will take about 10 minutes to finish but then you should have a fully functional printer again.
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on May 28, 2010
Ink system failure
Here is a link to a reset guide for your printer. You should have your printer up and printing again in no time at all.
http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/
I hope this helps, if so please rate my solution.
BuddyMc
Feb 17, 2013 | HP Photosmart D7160 InkJet Printer
Error Ink System Failure 0xc18a0201
remove the ink cartridge and print head and then do a power drain. after that insert the print head and ink cartridge.. if it still shows the 0xc. error try by replacing the print head .. first
Jul 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink System Failure The ink system has failed and can no longer print. Refer to printer documentation.
find out if it is giving you a specif 0x error message if not contact hp to see if a reset is avail for the ink system. unfortunately it sounds like the printer may be needing to be replaced
Apr 06, 2010 | HP Photosmart D7160 InkJet Printer
I keep getting ink system failure on my d7160 printer
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, press the power button to turn on the machine, wait until the printer prompts that the ink cartridges are missing, then reinstall the ink cartridges. If this doesn't fix the problem you may have to re-prime ink through the system. There is a good explanation of how to do this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 31, 2010 | HP Photosmart D7160 InkJet Printer
Oxc18a0101 error message ink system failure
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone. http://www.fixya.com/support/t451942-help THIS WORKED!!! Don't throw it out try this first for: Ink system failed Error16x16_smiley-surprised.gifxc18a0101 on photosmart D7160. This is to reset the error code only,you will need to explain in more detail why you got the code and what you've done to correct it.
Jan 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a Photo smart D7160. When trying to print it gives me an error message which says "Ink System Failure" Insystem has failed. Unable to print. Refer to printer documentation. Error: 0xc18a0307. Pls...
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com, click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
Buddy
Corporate Computer
www.ccl-la.com
Nov 13, 2009 | HP Photosmart D7160 InkJet Printer
Ink system failure
try selecting your printer in the control panel .right click on it.go to properties.select maintnence tab.select unclogg or clean print heads.etc.
Mar 04, 2009 | HP Photosmart D7160 InkJet Printer
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7160 InkJet Printer Logo
1,965 people viewed this question
Ben Johnson
