Question about Refrigerators
Sub zero making a horrible noise
Hello: i purchased an old (15+ years old) sub zero 351 and it has been working great until a few weeks ago it started occasionally making a small noise. now, it makes a horrible loud noise that lasts about 20 seconds and occurs about every 2-3 hours. it sounds like a buzzer alarm going off -- a very harsh, hard scary sound. it almost sounds more like it is coming from under the unit than above it, but i really can't tell. the fridge and freezer both are still cold. any ideas? thanks for the help! --marie
  • setme Oct 07, 2008
    I am having almost the same problem. However the fan is making noise. I removed the fan to clean from all the black gunk it had on it. I also used some WD40 to lubricate. My Sub Zero is about 10-15 years old. I need to know if might be the motor or the fan.
  • 770 Answers
If it is coming from under your unit is it most likely the water inlet valve for the icemaker check that and let me know you will have to remve the 2 screw on the kick plate to get to it,it should be on the left side
Posted on Apr 07, 2008
Compressor problem
is the sub is distorting then the "compressor" or voice coil will make horrible noises. Turning down the settings on the amp that is powering the sub will help decrees the noise.
Aug 20, 2012 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Sub-zero 430 stopped cooling.
The most likely failure (after a power outage) is your start capacitor or start relay. I would check them closely.
Jan 02, 2012 | Refrigerators
Grinding fan noise HP dv6 1130TX
First, if you just purchased the unit, you should have the problem fixed by HP under warranty.
HP offers a extended 1 year from the date of purchase. Thats 2 years on startup problems.
You are correct on the noise comming from the fan.
This will not go away and may get worse.
If the fan slows down or stops when needed, the CPU will go for a walk.
Email HP customer care and log your problem.
Make sure you have reg. your unit first.
Sep 16, 2009 | HP Pavilion dv6000z Notebook
My sub-zero fridge is about 20 years old. About a week ago, as it got hotter here in New Orleans, the beer bottles were sweating and not cold enough. So I adjusted the knob, and the next day everythin
what a **** way to make money. why can't you people just help people, instead of making it sound like you really wanna help, when all you really want is to make a buck. maybe i'd believe in your little program (sort of like a prob-specific online "Car Talk"), if I had some testimonials. Otherwise, find a better idea, guys.
May 12, 2009 | Sub-Zero 642
Under counter sub zero ice machine. stoped making ice
Try this! Clean water tube, Check Ice sensor ( small wire (red tip) set to close to ice plate ) To close ,no build up sets off to soon.
Dec 11, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sub-Zero 550 Fan Vibration
you could try taking the fan assembly out and adjusting it or oiling it, sometimes it gets that back pressure when the door is closed because it has to work harder
Jan 20, 2008 | Refrigerators
Whirlpoor Refridgerator 10-12 yrs old
I had a whirlpool fridge that did the exact same thing. Sometimes it was loud enough to wake me up at night! It is the compressor shutting down. I had it for several years untill I purchased a larger one, and then gave it to a girlfriend at least a year ago. Its still working good today. So if you can tollerate it, just live with it. Otherwise change the compressor.
Jan 04, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
WHATS THAT NOISE??!!
more likely a bad compressor, which is more sensitive to temperature extremes...may be cheaper to replace the frig.
Jun 10, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Refrigerators Logo
253 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
