Question about Logitech M-RBB93 Mouse
How do I connect my m-rbb93 - Logitech M-RBB93 Mouse
How to solve when usb mouse driver is corrupted in windows 7
Morning to you
I would uninstall the mouse and see what happens else it is the manual.
good luck
kolbrun
Feb 24, 2012 | Logitech M-RBB93 Mouse
I need a pairing code for a Logitech Bluetooth mouse M-RBB93
If the mouse refuse to connect, you should delete it from your Devices, then re-add. (for exact directions, Weldon Dube below has awesome step by step directions)
When it comes to paring, it uses the basic paring code of 0000 (4 zeros)
Jan 10, 2012 | Logitech M-RBB93 Mouse
I have S5350 model mobile, how can i transfer photos from mobile to my laptop?
Try to connect it in bluetooth connection. (Wireless connection.). Or try to connect your phone in USB connection. (Wired connection) For wireless connection:
-open your first your bluetooth connection. (phone and laptop) -send the the files/photos via bluetooth connection. -accept the files from your laptop.
For wired connection: -connect your usb to your phone -set your phone connection to mass storage -connect to your laptop, if your laptop detect your phone, search your files, then copy it.. =)
May 21, 2011 | Cameras
My M-RBB93 logitech mouse is recognized but before I can complete the process I need to give a pairing code number for it. It tells me it's either on the mouse somewhere or in the documentation. It's an...
This is such ****. What a waste of time. Logitech sucks. Spent hours trying to research this. Logitech manuals and FAQs provide no help.
Want to pair your crappy Logitech Bluetooth mouse with your laptop/PC? Going crazy trying to find your "pairing code"?
Try this: "0000" (four zeroes)!
Sep 15, 2010 | Logitech M-RBB93 Mouse
Logitech Bluetooth mouse short lifespan
Call logitech and they will replace it for free if it is still in the warranty period.
Feb 02, 2010 | Logitech Cordless Mouse
Instructions how to connect ps3 to internet
THERE 2 MANY WAYS YOU CAN CONNECT THE PS3 TO INTERNET:
1) WIRED CONNECTION
2) WIRELESS CONNECTION
1) WIRED CONNECTION
JUST CONNECT THE ADSL WIRE TO THE PS3. GO TO NETWORK SETTINGS AND CREATE A CONNECTION. THEN TEST CONNECTION.
2) WIRELESS CONNECTION ( THE BEST WAY TO CONNECT TO THE INTERNET)
IF YOU HAVE A WIRELESS ROUTER YOU CAN CONNECT YOUR PS3 TO THE INTERNET. GO TO NETWORK SETTINGS AND CREATE A CONNECTION. THEN TEST CONNECTION.
Jul 11, 2009 | Sony PlayStation Portable (PSP) Console
Battery in M-RBB93
For some cordless mice or trackballs, there is a slot for the battery door on the bottom of the mouse. Between the slot and the outside edge of the door is a thin strip of plastic. If you compress this thin strip of plastic towards the slot, the catch on the door will release and the door should open.
On other mice, the battery door is on the top of the mouse. Simply slide the top of the mouse cover down and lift the door up. There should be an etched diagram on the door indicating which direction to slide the door.
Once you have opened the battery door, remove the old batteries and dispose of them according to your local waste disposal regulations. Then insert the new batteries into the battery compartment using the diagram in the compartment as a guide. When you have finished inserting the batteries, close the battery door.
regards
Feb 21, 2008 | Logitech Cordless Mouse
Can't connect to 3Com Office connect wireless from Apple Mac Pro
PPPoE connection is set up
1. Control Panel, double-click Network Connections. 2. Click the PPPoE connection under the Broadband group that you want to share, and then click Change settings of this connection under Network Tasks. 3. On the Advanced tab, click to select the Allow other network users to connect through this computer's Internet connection check box. 4. PPPoE connections behave in a similar way as do dial-up networking (DUN) connections, and you may want the connection to be automatically dialed when another computer on your network attempts to connect to the Internet. To do this, click to select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box. 5. If you want to allow other network users to enable or disable the shared Internet connection, click to select the Allow other network users to control or disable the shared Internet connection check box. 6. Under Internet Connection Sharing, in Home networking connection, click the LAN (Local Area Network) connection that connects the computer that is sharing its PPPoE Internet connection to the other computers on your network.
Feb 07, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Logitech M-RBB93 Mouse Logo
220 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
