Question about Boating
I have a 97 Suntracker pontoon with 90hp merc with elect problem
I have a 97 Suntracker pontoon with 90hp mercury motor. The motor trim switch went bad last summer causing motor to come out of the water by itself. I fixed the switch and now I have no power to the right side of console. (ignition switch and trim switch. I know the trim switch fix worked because I jumped power to the toggle switch from the fuse box. However I am not getting power to the ignition switch or the trim toggle. Everthing else seems to be working properly. My question is can I direct wire the ignition switch and trim toggle from the battery?
  • 11 Answers
SOURCE: 1996 chevy s10 will not
check the crankshaft sensor
Posted on Aug 14, 2008
blueextc3221
  • 15935 Answers
SOURCE: No power to ignition - ? please help! 91 amigo 2.3l
If everything is turning on, and there's power... check for 12V at the alternator. it may be out now.... or a connector came loose, or wire broke.
Posted on Jan 09, 2009
SOURCE: Kenmore Commercial washer 110.20172001
Sounds like motor is bad. See if you can find the 2 main wire leads on the motor and hook up directly to see if you can get it to work.
Posted on Mar 05, 2009
  • 77 Answers
SOURCE: have 1975 Merc 115 h.p. motor. won't turn over with key
it may be your neutral safety switch. Try it again but this time turn the key with one hand and wiggle the throttle/shifter lever at the same time. My 25 johnson does this, but usually I can wiggle the shifter and she'll turn over. Hope this helps.
Posted on Jun 23, 2009
finish line
  • 207 Answers
SOURCE: power trim on 60 hp yamaha quit working
find the solenoid for the trim it will be a the engine or on the trim motor it self get a test lite and find the power wire on the trim motor and with someone pushing the trim button test the hot on the motor if there is no power it is the solenoid if there is power u my have a brush stuck in the trim motor itself but 99% of the time it is the solenoid u can tap the trim motor and see if that gets a result but dont hit hard
Posted on Jul 09, 2009
Where is the fuel filter on a 97 merc mountianeer
Should be under the truck in the fuel line.
Nov 24, 2015 | Cars & Trucks
I have a 03 Sun Tracker pontoon & Merc 60 my throttle trim will lower motor but not raise it.It works fine from motor ,up & down okAlso just had voltage reg. replaced and tach stopped working .Help
Time to just go threw all the wiring. You have a boat. It's on the water or not. On the water electrolysis kicks in 1000%. On land corrosion set in. Check and clean the wire plugs, replace if necessary. Replace ground point connectors. Add wire if necessary. Just a note. When I do boats, I solder all connections and use silicone shrink wrap on the wires.
Jul 01, 2015 | Boating
Why does trim on 90hp mercury goes down ok but only a small amount on up?
have you checked the OIL . they don't pump water or air very good
Aug 21, 2014 | Boating
Suntracker pontoon won't start and trim won't work
Trim want work ,,want start,, no power
Jul 04, 2013 | Cars & Trucks
My trim motor on my mercury motor settles
check for leaks in the lift system...
clean the rams and after they settle... raise them back up and see if the seals there are defeated.
Mar 30, 2013 | Mercury Outboards - Zinc Merc Outdrive
1979 evinrude trim problems
Replace the trim motor.
Jun 03, 2010 | RTO Oar Sockets
MOTOR SIT TOO LOW IN THE WATER ON PONTOON BOAT WHEN GOING OVER 3000 RPMS
you need to trim the motor by adjusting it so it is more vertical. It must be angled down into the water too much now and so it is pulling itself deeper in the water,
Oct 07, 2009 | Boating
97 merc villager driver side power window won't go up unless you" help" it,is motor or regulator bad?
The term regulator in reference to you window is a mechanical part,the motor is an electrical part.
Yes it can be either of the two.
you have to remove both any to remove the motor then you will see which is bad.
Aug 17, 2009 | 1998 Mercury Villager
Outboard problem
Check your prop...probably slightly bent and only is noticeable at higher rpms.
May 20, 2009 | 2008 Mercury Mariner
Boating Logo
126 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
