Question about Samsung SCHU960 Cell Phone
The touchscreen went out on my samsung SCHU960(Rogue). Verizon is sending me a new phone but I want to erase my data before sending it back. Is there any way I can do it without going through the phone`s menu? I can get the system restore via the voice command but I have no way to confirm the restore because the touchscreen doesnt work. Please help... BTW, I tried the reset code (*27-673-855#) but nothing happened
I had the same problem. I was able to gain temporary use of my touchscreen by placing a piece of tape (folded to make a handle) on the dark spot on my screen. This is where the layers were stuck together. I rebooted the phone while gently pulling on the tape handle to separate the layers. I was able to navigate to the restore screen and hit the yes button. There were points when it stopped responding. All I had to do was gently pull on the tape handle again to get the screen to respond again. I'm sure you have already solved your problem, but hopefully, this will help someone else.
Posted on Jan 17, 2011
  • mknefel Mar 24, 2011
    This was very helpful. Using this idea, I simply peeled the screen of the touch screen back just a bit (~3mm) with my fingernail on 1 side and then it worked again. No reset needed. Pushed the screen back down - good as new.
How do I reset my verizon htc innovation phone.
Resetting the phone will delete all data in it including your downloaded applications, and will resets the phone back to its initial state.
Press Home > Menu, then tap Settings > Security > Factory data reset.
On the Factory data reset screen, tap Reset phone and then tap Erase everything. To reset the phone using phone buttons, with the phone turned off, press and hold the Volume Down + Send + End buttons. The reset process will start after a few seconds.
Jan 25, 2012 | Samsung Computers & Internet
I forgot the password to my samsung rogue How do i access my phone?
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Apr 21, 2011 | Samsung SCHU960 Cell Phone
I need a master unlock code for a samsung rogue sch-u960
default password is the last 4 digits of cell phone number. If not you can try contacting your service provider to get the unlock code.
Mar 05, 2011 | Samsung SCHU960 Cell Phone
I have a Samsung Rogue that I got about 4 months ago. Recently, it has been acting weird. It shuts off randomly, and sometimes doesn't send or receive text messages. I have also had a few incidents...
Verizon has discontinued the Rogue. I loved it, at first, and I have grown to dislike it. It has lots of issues with sync-ing - blue tooth & USB connections. I have had trouble with mine charging from time to time as well. I had to have it replaced the first month I had it because touch screen stopped working. What I have found through trial & error - the best thing to do is to turn it off, slide off the back, remove battery for a few minutes and then put it back in (kind of like a control alt delete on a computer) - if it freezes up on you - try that. The other thing I was just told by a rep last week @ store is to charge it from wall, when possible, not through car charger or plugging it into usb on a computer(computer doesnt recognize it anyway - so that is really the only purpose of the USB port built into the charger) - I believe the Omnia is the replacement version that Verizon is offering in place of the Rogue. I think there is a strong argument to make with Verizon that they should HAVE TO replace your phone at NO COST because the Rogue is discontinued & the sold you a phone with KNOWN compatibility issues with Windows 7. - Whatever phone they do give you - they can sync the information onto the other phone without even looking at it & can delete all your personal information off of the Rogue. I watched them do it when they replaced my Rogue & she didnt even see the information that was transferred - so if its privacy concerns - you do not need to worry. I would love to hear how you make out - as I am fairly irritated with the USB/photo/non compatibility issue & intend to make the same argument in the very near future.
Aug 03, 2010 | Samsung SCHU960 Cell Phone
Can i unlock my phone and go to a new company? samsung verizon sch u960
To get the security code to unlock the cell phone from the current cell phone provider so you can use it with a different phone provider, Please click on this link and follow my instructions :-
http://www.fixya.com/support/r4049238-unlock_cell_phone
If your phone provider does not help you then this WEB site it provides security codes for a small price.
http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw
Try this WEB site also - Unlock Free
http://www.unlock-free.com
Jun 19, 2010 | Samsung SCHU960 Cell Phone
Touchscreen not working
do a hard reset first; when your phone is on, pop out the battery, and put it back again and start phone. check if problem is fixed. If not fixed, use this code *2767*3588#, note that this may erase all your data so if you can backup, then do. If problem still there, then it is hardware. take unit for servicing. you may have to replace either the touch screen or flex cable buts needs to open unit first and confirm.9look out for water damage e.t.c)
Regards
Feb 02, 2010 | Samsung Tocco Ultra Cell Phone
Smt5800
Same thing happened to me. i went to verizon store and they were able to reset it. all my info was lost though.. i believe this is how they reset it. hold down the two buttons on top of touch pad. the ones above the red and green phone buttons. at the same time press and hols power button. this reset phone and i am able to make calls,again all my info is gone but i can use phone again. there sending me a new phone anyway, but it is helpful to know how to reset it.
May 06, 2008 | Verizon Communications HTC SMT5800 Cell...
Phone restarting
ok heres what i did and so far it fixed the problem............i downloaded bitpim....... go to www.bitpim.org and get the program ...then find ur phone ..........then pick a picture on ur pic to be a wallpaper and then send it to ur phone ...oh yeah u will need a data cable to do this , u can find them on ebay pretty cheap ...dont get ripped off by verizon(30.00) and dont trust the offbrand cables try to get an authentic verizon cable.vcast kit...........it will reset ur phone dont worry its supposed to.....then save the picture to ur phone......after u do this disconnect the data cable and try to save a picture it should work
Aug 09, 2007 | Samsung SCH-a930 Cellular Phone
Samsung SCHU960 Cell Phone Logo
1,429 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
