Question about Craftsman 26 Hp 54" Deck Yard Tractor
Garden tractor does not start. Turn key and
Garden tractor does not start. Turn key and battery shows discharge but does not click or crank. Is it possible I have a bad battery. Battery installed is orginal (2004). Engine replaced last Sep or Oct by Sears under warranty. Was using when it stopped and will not restart. Tried jumping with my PT Crusiser. No go. Frank
  • 66 Answers
Hey Frank,
I would replace the battery either way with it being that old. If there is a dead cell in it, it won't allow enough juice to get to the starter. www.nnyparts.com
Posted on May 30, 2010
Why would my John deere sx85 only click when I turn the key
flat battery , bad terminals , loose terminals , rusty ground wire on frame , faulty starter relay , faulty starter solenoid
May 13, 2016 | John Deere Garden
My John Deere 1023e had a dead battery now it won't start
Sounds like the battery is discharging somehow. I would check to see if the key that starts it and controls the headlights is left on and allowing the batter to discharge.
Mar 01, 2015 | John Deere Garden
Engine will not crank
You need amps to crank the starter. Volts of the horn and lights. Get the battery load tested.
Oct 26, 2014 | Garden
I have 2000 john deere 420 and it wont turn over
The starting circuit is dependent upon the clutch safety ans PTO being off. Here are some steps to take:
1. Ensure battery is fully charged
2. Turn key on and turn PTO on then back off. Listen for clunk
3. Press clutch in fully and turn key to start position. If still no sound at all, hold key in start position and move clutch foot up and down, listening for solenoid click. If click but no crank, starter or solenoid or battery cable connection is bad. Start by wiggling cables, looking for any looseness. Next check solenoid and cables. If that doesn't fix it, starter or solenoid may be bad. There may be a fuse in the circuit. Check them out also.
if it cranks but doesn't start, you have a fuel or ignition problem. Good luck. Let us know what you find
Jun 22, 2014 | John Deere 420,1020,2010,2020,2510,2520...
My poulan pro lawn tractor won't start. when i turn the key it click's 1 time can you help ?
Have you checked the battery terminal connections? Is the battery charged fully? Are you sitting on the seat when you try to crank the mower? Could be any of the above but most likely battery connection or the battery is discharged or old.
Aug 20, 2012 | Poulan Pro Lawn Tractor 2006 and Newer...
I have a John Deere X300 lawn tractor with an intermittent starting problem. From time to time, when you turn the key all you get is a click. Battery is connected, headlights work, but starter will not...
sounds like the contacts are dirty in the solenoid if you jumper it with a screw driver does it crank over?also check the adjustment of the clutch/safety switch
Jun 12, 2012 | Garden
Was runnibg tractor, it suddenly cut off would not crank, put more gas in still no crank,, when turn key made a clicking noise , then a type of humming noise ,, battery is about two yrs old, got at...
Try jumping the battery with a car as long as the two are 12 volts.
If this starts the mower, it is the battery.
If the mower won't start with a jump, there is a different problem.
Mar 04, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Craftsman zero turn model# 107.27774
If you are jumping the solenoid and it cranks but wont start leave the key in the on position and give it a try. Try replacing the solenoid and the wires conecting it to the battery.
Apr 24, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Garden tractor, starter motor does not crank
Your starter may need to be rebuilt or replaced.
Apr 04, 2009 | Garden
Craftsman 26 Hp 54" Deck Yard Tractor Logo
186 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
