Question about Magic Chef 31000 Gas Kitchen Range
I keep getting and alarm sound like a timer going off...screen says f1 when this happens
    President:
  • 1,430 Answers
F1 indicates a stuck key or the ERC electronic range control has failed. The key pad membrane is more likely the problem. Check each key by depressing and feeling for it retracting, if any are stuck replace the membrane. Also inspect it for ant burn marks or defects. If all loooks good then replace the main control ERC. They are easy to replace. Enter your model # at www.appliancehelponline.com for diagrams and illustrations of your specific model.
Posted on May 27, 2010
Samsung galaxy s3 alarm not working
Check your Blocking Mode settings. It may have alarm and timer blocked.
Dec 06, 2012 | Samsung Galaxy S GTI9000 Smartphone
Alarm goes off for no reason
It can be any of the car door not got properly locked or the door is locked but the switch is not sensing the door locked.Open and close each door again properly.
Or else its problem with any of switch wiring getting in contact with alarm wiring causing it to happen.And last thing alarm connections needs to be inspected.Its getting short somewhere in between.
There are few helplinks with solutions,to troubleshoot these types of problems.I suggest going through these links.
Click the link below:------Volvo car alarm keeps going off for no reason http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
------------------ Alarm keeps going OFF http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
--------------2009 Toyota Camry: Hood Switch causing Alarm to go OFF? http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
----------------Ford Pickup Alarm will not disengage? http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
------------Mitsubishi Diamante: Factory Security Alarm will not go Off http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
------------Toyota Avalon Factory Alarm will go off? http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
----------Chevrolet Tahoe Hood open warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
-----------These details will help.Thanks.
Nov 24, 2012 | 2005 Lexus ES330
Hii i have kenmore kitchen range and itz givin a F1 error and keep beeping please help me out with this beeping sound is so anyoing
Hello there:
Here is the code and what it means read the code i have provided and what needs to be donte to repair it ok but first here is a thing you can try first unplugthe oven for 1 hr to let the internal memory module reset itself then try it again if you get the same code than here is what is wrong
F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERCplease keep me posted on how this is going so i can assist you more if you need to get parts or some thing else ok
Best regards Mike
Jan 01, 2011 | Kenmore 72002 / 72004 Kitchen Range
Need two timer alarms.
My reading of the instructions is that the answer to your question is "NO".
See the section on "Alarm". This indicates that there is no repeat function that you require.
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 26, 2010 | Timex T5E501 Ironman Triathlon Sleek 50...
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
F1-8 code timer # 1 keeps going off on
good day,
hope this link below will solve your problem.
kitchen appliances
Dec 29, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
F1 display and alarm will not shut off
hi there,
can you tell me the model # on your stove please?
Sep 13, 2008 | Maytag CWG3100A Gas Single Oven
Keeps beeping
My thermador keeps beeping and F1 stays on...what's happening and how do I get it to STOP!
Oct 08, 2007 | Cooktops
Alarm Keeps Sounding
I WOULD REPLACE THE TIMER OR POWER CONTROL BOARD
Dec 29, 2006 | Zanussi TC7102W Electric Dryer
Magic Chef 31000 Gas Kitchen Range Logo
598 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Sal De
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
