Question about ViewSonic VA2226w 22" Widescreen LCD Monitor
I have a viewsonic VA2226w and when i'm away from my desk for more than one hour the monitor display dims. the work around i need to do to make it go to it's original state is to turn off the monitor and turn it back on. any solution to my madness would be greatly appreciated.
  • 11,361 Answers
Look for bad caps in the power supply section, that will be the first place to look. 90% of LCD monitor failures are due to bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 28, 2010
We have a Viewsonic VA2226W that goes to black screen after 15 seconds or so, is it toast or is there a way to fix?ViewSonic monitor VA2226w
Make sure you are supplying a valid timing mode to the display. Call ViewSonic technical support to resolve your issue.
Oct 01, 2014 | ViewSonic VA2226w 22" Widescreen LCD...
My view sonic va2226w monitor is black but blue power button keeps blinking
Check for bad caps with bulging/leaking tops as shown here first:
http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VA2226W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 02, 2011 | ViewSonic VA2226W LCD Monitor
Viewsonic - VA2226w - dual monitor configuration. Monitor is black / no image- all test pass showing monitor is functioning properly.
Swap this monitor with the main one.
If it works, you may simply not have the secondary output enabled in the operating system.
In Windows for example, in the video properties, there's a place where you choose which video card you're dealing with (and/or which output or monitor) and there's a checkbox that says "extend my desktop to this monitor"
If that's not enabled, monitor 2 will be blank !
If the monitor doesn't work in the same connector that the working monitor is in, you may have bad capacitors in this one.
Watch the video below on how to fix that issue.
Mar 25, 2011 | ViewSonic VA2226w 22" Widescreen LCD...
ViewSonic VA2226w, horizontal light coloured lines through image regardless of resolution. They get worse when the monitor has been running for a while. Display otherwise working, powers up and down fine...
The lines appearing on the screen have nothing at all to do with the resolution. If the OSD display is correct (when the LCD is not connected to the PC), then the possible issue could be the RAM. Open the PC case and check if you have more than one RAM stick. Try using one RAM at a time and swaping RAM slots to see if the display is shown correctly. Make sure that the PC is turned off and power is disconnected before you remove/ install RAM. Most of the times lines appearing on the screen are due to faulty RAM. I suggest that you may also connect the LCD with some other PC to check if the issue is with the LCD or not.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 18, 2011 | ViewSonic VA2226W LCD Monitor
After waking from sleep mode, monitor resolution is a mess!
Try reinstalling the graphics drivers. and possibly a different graphics card.
Apr 14, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
ViewSonic VA2226W LCD Monitor unlock power button
Try holding the vol+ & vol- or hold the vol+ & Menu and lastly try the ch+ & ch- buttons. When doing this you must do it from the tv not the remote, and hold them down for ten seconds or until it says it has unlocked.
Apr 04, 2010 | ViewSonic VA2226W LCD Monitor
When Monitor has been switched off for 8 hours it takes 5 minutes to get back up again. Once up it will work perfectlt
This monitor is more than 2 years old, time to look for bad caps with bulging top in the power supply, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 19, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
ViewSonic VA2226w 22" Widescreen LCD Monitor Logo
148 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
