Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Need to adjust the color on a big screen mistubishi tv
Do we need the remote to adjsut the color on a 52 inch big screen
Mistubushi Tv?
  • dmarous May 28, 2010
    We just want to adjust the color, do we need the remote to do that, we do not have the orginal remote?
  • 94 Answers
The DM assembly needs to be replaced
Posted on May 28, 2010
Toshiba mv19m4..can i get to the menu without a remote? Want to adjust brightness..
YES THER WIIL BE A BUTTON THAT SAYS MENU DOWN BELOW AND THERE YOU CAN ADJSUT THE BRIGHTNESS CONTRAST SHARPNESS AND SOMETIMES DENSITY OF THE SCREEN INCLUDING THE COLOR
Dec 04, 2016 | Toshiba MV19M4 19 in. TV/VCR Combo
I have a old Phillips big screen TV. Serial# 72630137 Model# 60P8342A. No remote the p.o. tire has too much red. How do I adjust my picture.
GAIL,YOU NEED THE REMOTE THAT CAME WITH YOUR TV IT WILL ALLOW YOU TO ADJUST THE COLOR AND CONTRAST BRIGHTNESS YOU MUST GET INTO THE MENU TO DO THIS BUT YOU DIFFENTLY NEED THE REMOTE THAT CAME WITH THAT TV!!!
Jan 24, 2016 | Televison & Video
Horizontally the picture is distorted (doubled). Sound is ok. we have a 52 inch RCA big screen tv.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Feb 21, 2010 | RCA P52926 52" Rear Projection Television
I have a 52 inch RCA projection tv. Where are the color adjustment screws on the back of the tv that everyone keeps telling me about?
This is Chassis PTK195-There are screen/focus adjustment knobs (red green and blue) at the front of the set - behind the speaker grill and front access panel.
Oct 11, 2009 | RCA P52926 52" Rear Projection Television
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
RCA MODEK D52W17 Cant Get Any Remotes To Work This TV
The remote receiver in the TV is failed. It is possible that a TV repair shop might be able to fix the problem for you
Jun 18, 2008 | RCA HD52W58 52" TV
check all connections and different sources(dvd, vcr, antenna) to make sure that it is the tv. otherwise i would say call a technician because you could be in for some extensive troubleshooting
Jan 25, 2008 | RCA P52960 52" Rear Projection Television
RCA 52" big screen tv
sounds like one of your tubes got weak, im thinking the red tube, needs to be adjusted manually
Dec 26, 2007 | RCA P52937 52" Rear Projection Television
Projection red is above other colors
Look in your menu for something called "horizontal static convergence" or just "convergence". Adjusting this will align all three tubes electronically. If physical adjustment is needed, then you have to do this manually inside the Tv. keever
Dec 09, 2007 | Mitsubishi WS-65908 TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
238 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
