Question about Poulan Pro Chain Saw 46cc 20"
Idle how do i adj. idle
    Brigadier General:
  • 4,088 Answers
The 'H' and 'L' jet needles on late model saws have 'D' heads requiring a matching screwdriver that only servicing dealers have (thank the EPA). The idle speed screw is owner adjustable and is set so that the chain stops turning, but the engine keeps running. Hope this helps!
Posted on May 28, 2010
Homelite d725cd
not sure what you're trying to accomplish but the idle screw and low speed mixture screw work together. most 2 cycle trimmers idle happy at 3k rpm's... just before clutch engagement
Aug 28, 2014 | Homelite Mighty Lite Lawn Trimmer
99kawasakiprarie300valveadjustment
MOVE EACH CYLINDER TO TOP DEAD CENTER OF COMPRESSION STROKE ( sorry caps on .) check that timing mark in timing cover hole is in line .remove adj cover per cylinder in alignment and adj valves according to mfg specs. to adj : under adj cover , loosen lock nut on top then loosen adj nut on btm @ top of valves . insert feeler gauge under rocker and adj ,this is tricky to say the least. usually takes several tries to get it right, keep trying the valves must be set right or major expenses can be expected to occur. intake and exhaust settings are different normally at least .005 .be sure to tighten locknut on top before checking if clearance is correct. holding the btm nut while turning the locking nut is the tricky part 4 me anyway. 2 valves per cyl. on most atv eng. adj all valves .start eng and listen to eng w/o reving up. any ticking noise and you get to start over. should be smooth idling and quiet. no popping or backfiring. smooth starting and off w/o run on. should not be performed unless you are familiar with the procedure. contact me or service center near you if not sure on procedure.correct adj. is slightly snug fit . valves making no noise when done .
Jul 12, 2014 | ATVs
Runs slow
In California the new blowers have sealed mixture adjustments and you need the have your carb. mixture adjusted be a qualified shop. If your carb. HAS mixture adj., turn the high speed mixture so it runs best at high speed, then turn another 1/8 turn counter clockwise to be a little rich. Then at idle adj. the other screw till it idles best.
Apr 21, 2014 | kawasaki Krb300a Backpack Leaf Blower
How do I adjust throttle cable on 1989 chev c2500 to raise idle speed throttlebody injection
Can't adj..clean your IAC. Idle Air Control valve, or possibly replace it. The Computer adj's you idle by this valve moving in and out, it gets carboned up and does'nt move like it should.
Feb 13, 2012 | Chevrolet C2500 Cars & Trucks
Tk carb ? sthil trimmer has 3 adj screws ,how do you adj?
One adjustment screw (probably Phillips-head) is the Idle speed adjustment screw. Turn it in, to increase idle speed (it moves the throttle plate)...turn it out to slow idle speed down. The other 2 screws are the Low mixture screw and the High mixture screw. The L screw is closest to the engine and is used to adjust the engine at IDLE. The H mixture screw is to be adjusted when the engine is at wide-open throttle to get the proper RPM's....not too little and not too much. Here is a tutorial by Zama carburetor reiterating what I have just told you and HOW to go about your adjustment.
http://www.zamacarb.com/tipspage.html
Sep 11, 2011 | Garden
Kohler engine carburetor adjustment on John Deere Model 112
When u adj a kohler carb you adj fuel not air. Always adj the high speed then low speed. Then adj the curb idle. 1.5 turns out is a good starting point. Then tweak it after its warmed up. Hope this helps
Nov 17, 2009 | Garden
Husky 350 chainsaw idle to high
First there is an throttle idle screw that adjust the amount of throttle at idle try turning it ccw until it idles down. If this adj is at its lowest level then adjust the L screw until you get the idle you want. Then try to rev up it should rev up without hesitation if not hold down on throttle untill you get max rpm it it tries to cut out etc. at high rpm adj. the H screw until you get max rpm. then adj your L screw again for proper idle. You may need to do this back and forth for awhile until you get max. performance.
Apr 10, 2009 | Husqvarna Garden
Engine runs but wont idle!
set you carb adjustments at 1 1/4 and try that
Jan 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
IDLE FLUCTUATION
adj idle with cable adj thanks Trevor
Aug 05, 2008 | Ford GT Cars & Trucks
Poulan Pro Chain Saw 46cc 20" Logo
99 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
