Question about Refrigerators
Freezer coils at back get frozen thru to plate at back. Cold air does not get thru to fridge sufficiently. Now we have freezer set between 0 and 1 and fridge at 6. Freezer is extremely cold - fridge normal. What is the problem? Pls give us some ideas as to what could be causing this. We are on the point of buying another and this one is not that old! Jean Welsh
  • Anonymous Aug 10, 2008
    Maytag MSD2957. About 1 / year (for the last 2 years) the coils at the back of the freezer have become totally frozen (apparently the defrost cycle is not working properly). By doing a "manual" defrost the refrigerator again works normally. Is there a recommended series of items to check?
  • Gary Davd
    Gary Davd May 11, 2010
    sounds like you have a defrost problem but need the model # to get into the unit futher plz post it
I did not get any reply/information from you.
Jean Welsh
Posted on Apr 09, 2008
Model #GSS201EMA WW FA226779
Jean Welsh Welshmb@roadrunner.com
Posted on Apr 08, 2008
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
My ps 123sc is not cooling properly. it seems to be blowing some cool air but not enough to keep the freezer stuff frozen
Hello Drhoffs,
I understand that you are having a problem with you GE Refrigerator. The unit is blowing some cold air but not cold enough to keep items in the Freezer frozen. There are a few possible problems that can cause this situation:
1. Condensation coils are dirty
2. Fan not working (unplug unit)
3. Freezer coils are ice up (unplug unit)
4. Low on Freon (requires a service Tech and can be expensive)
Lets take this one step at a time thru the possible causes of the issue:
1. Condensations coils are dirty: You will need a vacuum with a crevice tool or air compressor or a long handle skinny brush>
a. Remove the kick plate on the bottom of the fridge
b. Use the above mentioned tools to remove all debris from underneath the fridge in the coils this can be accomplished from the front and back of the fridge
c. Once done reinstall the front kick plate
2. The Fan (if you can not hear the fan then follow these steps)
a. Remove all items from the Freezer
b. Remove the rear panel inside of the Freezer compartment
c. Locate the fan notice if the is turning if not remove and got to local hardware store and purchase a new one
d. Reinstall everything in reverse
3. Freezer coils
b. Remove the rear panel located in the back of the Freezer
c. Use a fan or heat source to speed the defrosting of the unit (it is also a good idea to put a cloth or something in the bottom of the Freezer to collect the water so that the Freezer pan does not over flow.)
d. Reinstall all items in reverse
4. Freon Level: This requires a licensed service technician and can be costly, weight the cost of the service call and repair to the cost of a new unit. If the cost to repair is more than half the price of a new unit purchase a new unit.
Thank you for choosing FixYa.com
Justin
Mar 28, 2011 | GE Profile Arctica Stainless Steel Top...
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 | GE Freezers
Wawwwwtewwwwwar
Hi!!
Make sure drain hose is not clogged up. Check evaporator fan, (small fan in freezer compartment). it should come on after door is open a couple of minutes. Feel air vents in fridge side for a stream of cold air, if none or too weak, remove back cover (where fan is) and check for frozen evaporator coil. If evaporator is frozen, air can't circulate thru unit, keeping fridge side from cooling and freezer side below freezing point.
If this is the case, unplugg unit from power outlet, and use a heat gun or hair dryer to melt ice, make sure all vents are clear.
Once the evaporator coil is free of ice, dry freezer, replace back cover and plug unit back on. Check temp. settings, should be about 1/3 of the dial range. If necessary, make additional adjustments every 24 hrs.
Don't forget to rate this post!! Good Luck!!!
Jul 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Refridgerator side is set to 34 but temp reads 52 last night freezer was at 20 when set to 0 cleaned coil of dust now reads 0 but fridge side still wont come down it is a GE side by side
your evaporator coil in the freezer behind the rear panel is iced up and cold air cant flow thru ice,defrost the evaporator coil,then check continuity of the heater element under the coil,if its good,then suspect the defrost control,usually located in the refrige side on the upper area
Jul 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer gets 10 below 0 and fridge is 60 degrees
Check and clean the condensor coils. Make sure the air ducts are free f frost and not blocked by anything. Make sure the light is turning off when the door is closed.
Eric
Sep 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer working well fridge not working at all
there is a fan in the back of the freezer that pushes air into the fridge side of the fridge it sounds like this has gone out on you. this fan is usually right by the coils in the freezer the only thing that keeps the fridge cold is a little air being pushed over there constantly
Apr 27, 2009 | Refrigerators
Jenn Air JCD2389GTW Refrigerator problem
change the adaptive defrost board located in the upper right corner of refrig under the panel. remove panel by pulling on panel towards you from the finger holes in the rear. remove two 1/4 inch screws and two phillips screws. defrost manually with hair dryer behind panel in freezer.
Jan 19, 2008 | Jenn-Air JCD2389G Side by Side...
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
219 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
