Question about Hannspree (K206-10U1-005) Television
My JT01-32E2-000G Hannspree 32 inch has a 3 inch gap down the right side of the screen.Can this be eliminated by some sort of adjustment?
Search datasheet for power panel for hannspree jt01-32e2-000g
Posted on Sep 15, 2010
My 32inch tv turns on but the picture is wired.
On a 32 inch it may not be worth fixing--not going to be a reset etc--base decision on fact that possible repair should not exceed used value of set--which in my view it likely will.
May 26, 2012 | Hannspree (K206-10U1-005) Television
I have a euro-pro sewing machine that i got second hand, came with no manual so i dont know whot to set it to basic stich it has all these knobs and i have no idea how to run it normally
Hello
The stitch dial for the length is located all the way on the right side of the machine and is factory set at the setting "3," which is a 3mm or 1/8 inch length. Turn the dial up or down to adjust the length. For example, the setting "4" is 4mm (5/32 inch) and "2" is 2mm (5/64 inch).
The width of the serged seam is dependent on the needle or by adjusting the knob for the width. With the left needle only sewing, the width is set to 7/32 inch, and with the right needle only sewing, it is set to 9/64 inches. Additionally, by pushing in the width adjustment knob behind the front cover, the stitching can be adjusted manually from 1/8 inch to 17/64 inch wide.
Jul 23, 2011 | Euro-Pro Deluxe 6130 Mechanical Sewing...
The print is only clear on the left side of the forms...
Platen Gap Adjustment (Figure 35)
IMPORTANT Only do this procedure if the original equipment shuttle frame assembly or platen has been replaced by a new or
refurbished unit.
1. Prepare the printer for maintenance (page 338).
2. Remove the shuttle cover assembly (page 357).
3. Loosen the platen open belt (page 415, steps 2, 3, and 4).
4. Raise the forms thickness lever (1) to the fully open position.
5. If you are adjusting any model except the 6400-i20, select a 0.011 inch (0.28mm) flat feeler gauge.
If you are adjusting a 6400-i20, select a 0.012 inch (0.30 mm) flat feeler gauge.
ATTENTION Do not force the platen against the feeler gauge. Damage to the hammer tips will result.
6. Insert the feeler gauge (2) straight down between the hammer bank cover plate (3) and ribbon mask (4), within four
hammer positions of the left end of the hammer bank.
ATTENTION Adjust the platen set screws less than 1/4 turn on one side, then check the other side. Adjustment sensitivity is
approximately 0.03 inch per revolution of the set screw. Also, insert the feeler gauge no more than two inches down
from the top of the ribbon mask.
7. Gently close the forms thickness lever (1). As the platen is closing, gently slide the feeler gauge up and down, keeping it
between the hammer tips and ribbon mask. If the feel is too tight as the platen closes, adjust the 3/32 inch set screw (5)
counterclockwise. If the feel is too loose, adjust the set screw clockwise. With the forms thickness lever closed all the way,
the feeler gauge should contact both the tips and the ribbon mask and move with light friction. Shift the gauge slightly to
verify.
8. Repeat steps 4 through 7 at the right end of the hammer bank.
9. After adjusting both sides, check the gap again at both ends. Readjust if necessary.
Aug 25, 2009 | IBM 6400 Matrix Printer
Blank part on my monitor
This sounds like a claim. Give it back to your seller.
May 28, 2009 | Hannspree HANNS·G HC174DP 17 inch LCD...
Onscreen controls don't respond
You have five buttons at thee right-hand bottom of your screen (just under thee edge). They are (from
left to right) the Main Menu button, the Down button, the Up button, the Input button and the Power
button (under the light).
To adjust your screen press the main menu button. Once the main menu screen is up, toggle
through it using the Up/Down buttons. Once you see what you want to adjust, move over to the
right side of the menu by pressing the Input button. Now use your Up/Down buttons to highlight
what you want to change. Once it is highlighted, press the "Input" button again. Now use the
Up/Down buttons to adjust your settings.
Once you have adjusted the settings, simply press the main menu button to exit.
Sep 10, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
"melting" screen image
the problem is the backlight not lit evenly.
have the backlight inverter board checked for correct ac ht and if that is okay then u will have to replace the backlight.
Jul 10, 2008 | Polaroid Televison & Video
Wire on tv screen
it is a simple job to fix that. you need to take the whole TV apart and there is a black gasket that falls down on all these TV's. the glue that was on the gasket and the weight of the screen pulls it down more and more. takes about 1 hour by an amateur doing this maybe less for a professional.
Jun 02, 2008 | Protron PLTV-32 Television
Hannspree (K206-10U1-005) Television Logo
401 people viewed this question
Top Hannspree Televison & Video Experts
Ricky Lee
Level 1 Expert
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
