Question about HP Photosmart C4180 All-In-One InkJet Printer
Printer plugged in but no response when power button pushed. Could power supply be dead?
  • 903 Answers
The power supply could certainly go bad. Have you had any power surges or outages recently? Do you use a surge protector? Is there any other device plugged into the same circuit that is having problems?
You can probably find a new power supply for your printer somewhere online, but between the cost to buy it, cost to ship it, and time spent replacing it, you're probably just better off buying a new printer.
Posted on May 28, 2010
ML350 G4 will not boot. System was running but became unresponsive. Powered down using power button. Now no response to pushing power button. No Leds lit anywhere. Fans running on power supplies.
Try pulling the hot swap Power supplies, push the power button hole the supplies are out to discharge power, then put them back in again and try the power button again.
Oct 28, 2013 | HP ProLiant ML350 G4 Server
I accidentally plugged my hp photosmart printer into the wrong power supply and now my printer will not turn on. Is there a reset button on this printer?
You can look for a reset button on the rear,bottom or sides of the case but I doubt that you will find one. If you plugged the wrong power supply into the printer the printer's internal power board is probably damaged.
You cannot fix it yourself as you do not have the schematic or wiring diagram of the printer and you probably don't have the test equipment required to isolate the failed part(s)You will have to take your printer to a store that repairs printers and copiers.
If you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Regards,
Yavacotech
Dec 09, 2010 | Office Equipment & Supplies
Our canon MP560 printer will not turn on - it was plugged into a surge protector and we have tried moving the plug to alternate outlets just to make sure that wasn't the problem...help!
This is what worked for me. I had a similar setup and could not get the printer to turn on. Remove the power supply from the back of the machine. It is a very simple process: pull apart two small plastic connectors with your fingers to remove power supply. Disconnect internal blue cable from power supply.
Replug blue cable and be sure it is plugged in tight.
Push power supply back into place, be careful of blue cable when pushing it back into printer.
Plug in and printer just may work...good luck!
Jun 28, 2010 | Canon MP560 All-In-One InkJet Printer
My printer does not turn on?iam pushing the on button.
Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. With the other end of the power cord still plugged in to the power outlet, the power supply of your Lexmark X5650 should have a green light on around the silver contacts. If not, you might have a defective power supply. If that's the case, I suggest you contact Lexmark Technical Support for the power supply request. If there is, plug it back in the printer all the way through and in a correct position. Printer should power on automatically, otherwise, press the power button. If printer is still not powering on, it might be defective now. Contact Lexmark Technical Support for further troubleshooting.
May 11, 2010 | Lexmark X5650 All-in-One InkJet Printer
My HP 1610 printer is plugged in and non-responsive. I push the "on" button, but it's completely dead. I've been away from home for a week, so I thought maybe it was related but I'm not sure. How do I...
hello.
try to remove the Cartridge then power it on if the same problem the problem is the power Supply main board.. if not the power cord.and loose solder in a power supply.thanks
Mar 29, 2010 | HP PSC 1610 All-In-One InkJet Printer
Laptop just died...power/battery???
It could be one of 2 things. Dead battery or hard drive is dead. Your biggest problem is you never backed up your info.
May 17, 2009 | ASUS F3SC-B1 Notebook
Tv wont come on at all..push the power button.. nothing, use the remote..nothing, not even a flicker...please assist
hi..this is probably an issue with the power supply
of the tv.check the power supply.
thank u..
kindly rate my response..
May 09, 2009 | Protron PLTV-37 37 in. LCD Television
Tatung V30DMTT 29.6 in. LCD Television won't power on
bad power supply,common problem w/tatung,re-build power supply
Jan 04, 2009 | Tatung V30DMTT 29.6 in. LCD Television
Epson stylus photo r320
You may have a problem with the switch panel board. If you disassemble it, you may be able to test the panel by shorting the two connectors to the power button. On the other hand it could be the power supply that is dead on the output side. Both are problems that do occur with R3** series but not that common.
Sep 16, 2008 | Epson Stylus Photo R320 InkJet Printer
W8400 powerless
plug it in or keep finger on the power button longer.
Feb 19, 2008 | Canon imagePROGRAF W8400 InkJet Printer
HP Photosmart C4180 All-In-One InkJet Printer Logo
120 people viewed this question
Seeker5211
Seeker5211
