I have an 8 year old RCA P52940 rear projection TV that blew the input 5 amp fuse but now after I turn the TV back on the picture is not very clear and almost makes it look like you are looking through a balloon. And the figures on the screen have shadows making it look like you are seeing double vision.
  • 8,617 Answers
Sounds like the convergence amp ICs are bad and need to be replaced if your seeing things in almost a 3D image
Posted on Apr 07, 2008
SOURCE:
We have no picture, but sound, and the picture is working on menu, and setup. hooked to spare tv and picture works.
the input is bad try another input. if same problem input board is bad replace it. could be time to try a new set.
Dec 26, 2010 | RCA P52940 52" Rear Projection Television
Reset button on 52 in rca rear p52940 home theater projection television located
this set does not have a reset button if there is a system lock out unpluging it for 3 or 4 mins will reset when pluged back in
if that does not help try trouble shooting the set ck the ac fuse and so on
Oct 24, 2009 | RCA P52940 52" Rear Projection Television
Rca r52wh74 - no auto convergance
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Dave.
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P61929 picture problem...
The TV was working fine, some time during the night the power went out, its plugged into a surge protector, everything else works fine, the TV won't turn on, the fuse is fine, is there a reset switch?
Dec 06, 2007 | RCA P61927 61" Rear Projection Television
Picture flipping
The P52940 uses the 195 series chassis. The vert/hgt control is for vertical height. It adjusts the size of the picture from top to bottom. If your picture is flipping, it most likely means that something is wrong in the vertical circuits. I have seen fluid leak out of one of the CRTs and drip down on the vertical output IC, causeing the picture to go crazy vertically. The set should be serviced by a qualified tech experienced in the RCA 195 chassis.
Aug 18, 2007 | RCA P52940 52" Rear Projection Television
RCA P52940 Television
The P52940 uses the CTC195 series main chassis. The most common reason for the set not to start up is a shorted flyback (high voltage) transformer. The set actually does try to start, but the computer immediately detects the extra current drawn by the shorted flyback and instantly shuts the set back off. The chassis should be checked and the flyback replaced by a qualified tech familiar with RCA projection TV's.
Aug 12, 2007 | RCA P52940 52" Rear Projection Television
Rca 52 inch rear projection
This is a problem common with some RCA/GE TV's. The fix in the past was to install a capacitor between ground and pin 15 of the microprocessor which keeps a data signal riding on the video stream from muting the sound on most stations. By installing this capacitor, you would be disabling the closed caption feature so that feature would no longer work. An authorized RCA TV repair shop may be able to give you more information.
Apr 12, 2007 | RCA P52940 52" Rear Projection Television
Open Questions:
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
