Question about Viking VMOC205SS Microwave Oven
My viking professional microwave is shooting sparks and caused a burn mark on the inside of the oven wall? Can I fix it or is it shot?
  • Viking Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the metal of the oven wall is burned or chipped, the area will first have to be sanded smooth and cleaned and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth, then apply paint.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
Posted on May 28, 2010
NN-CT552 combi. What caused two burn marks On top of the door and on the frame?
The inside of a microwave oven has a special paint on it. If the paint becomes damaged, the microwaves strike the bare metal and arc. This leaves a burn mark. It will also ruin the magnetron inside the oven.
Jan 23, 2016 | Panasonic Microwave Ovens
Sparks when cooking
Make sure no metal item (forks-spoons or oven rack) is touching the outer wall of the microwave. That will cause sparks. If all that is OK then there is usually a metal fan type blade in the microwave top called a stirrer blade that may be out of place and rubbing the cavity causing sparks. Try to pin point the spark area so you know where to look for the problem. Sparks usually mean metal is touching metal somewhere.
Mar 29, 2015 | Whirlpool MH7135XE Microwave Oven
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
What cause sparks to shoot inside the Daewoo KOR-1B4H Microwave Oven when it is empty?
You should never run a microwave with nothing in it!! There is nowhere for the energy to go. The oven itself has a special coating that keeps the sparks from happening. Anywhere the coating is bad will arc. If it keeps arcing it will burn out the microwave generator.
Oct 02, 2013 | Daewoo KOR-1B4H Microwave Oven
When I turn the microwave on it runs fine for first few seconds the. It starts sparking from that plate with the burn mark. What is going on?
I'm sorry to say, your unit is shot! Once the control of the microwave signal is deflected like that, it is DANGEROUS to operate. It may not be worth fixing. Replace it!
Jan 20, 2013 | Microwave Ovens
I get an occasional spark when microwave is in use
Presuming that you have iliminated the possibility of any metal objects that are not meant to be in the machine being in there (and this includes dishes and other items with silver or gold leaf on them, which WILL spark and burn!) then take a look inside the oven its self. You will find a waveguide cover. It is usually a strange flakey silvery plastic/card like material called Mica and is usually on the same side of the microwave wall as the control panel (So if the picture on this thread is accurate, I will guess the Mica cover is on the right hand wall inside as you look at the machine from the front) . Over time, the magnatron (the thing that creates the microwave energy) will often burn a hole through the mika, or cause a dark brown or black burn mark in it. If this cover is even slightly damaged then it may well cause sparking inside the machine. These covers are designed to be removed and you can buy replacements for them from electrical stores.
Aug 12, 2011 | GE Advantium SCA1001HSS Convection...
Microwave sparks inside oven in the area of the sealed compartment when it is started
If unit was run for long time with food on walls and not cleaned off, it is possible that the unit was burned in a spot where the food was and if there is metal frame under that part for the finish it will spark. Check closely for burns, if it is sparking due to that problem, junk it. It is a dangerous condition.
Jul 28, 2010 | Daewoo KOG-867T Microwave Oven
My Viking microwave is sparking from the right side when turned on. I removed and cleaned the guide cover as I read about on your site and it still sparks. Is there anything I can do to fix this? All of...
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or in the waveguide behind the waveguide cover.
Otherwise, there may be grease or food particles deeper in the waveguide or even on the magnetron itself.
May 25, 2010 | Viking VMOC205SS Microwave Oven
My Sanyo 1000W microwave is shooting sparks!!!
you need to replace the cavity cover "the cardboard like",the antenna bearing set "the gun barrel like" and the gear motor.If the "gun barrel like" is stuck up because the gear motor is not rotating excessive heat will occur inside the microwave thus burning the cavity cover.
Mar 20, 2009 | Sanyo EM-A5200SW Microwave Oven
Viking VMOC205SS Microwave Oven Logo
485 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
