Question about Goldstar WG5000 Air Conditioner
I have a goldstar LWA0510CL 5,000 BTU window unit that is putting out air, but the air is not cool. Any advice?
  • 67 Answers
SOURCE: how large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
if this helps please vote me a fix ya
Posted on Jul 21, 2008
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not cooling
hi! there well it seem all you mention to your aircon doesn't have any problem physically at all.with that there is still posibility that the heart of cooling system is the sympton that you mention internally speaking of compression,you have to check also the performance of your compressor effeciency.doing yhis primarily.we can rely on oprating pressure and operating current flowing in your system while running,this actually give tou yhe idea what really the condition of your ac internally.run your unit using clamp ammeter tester check your amper actual operating current clamp your tester one line of 3 lead compressor take the reading,then compare this reading to your rated compressor, current usually indicated to your manual diagram and tag plate on your compressor. if your actual ampere reading is below need to recharge the sysrem but if haas a asme value actual and rated you system is good is good. , as you can see if your thermostat is working properly you have a good airconditioning system,try to see set up of temperatur,try to the coolest point or maximum adjustment and observe the cooling effect if the blowing air on evaporator is strengthning the cooling effect increase,but if no change the problem is on blower or blower control sensor as you increase yhe speed of blower the cooling air increases.lastly the pressue from hi and lo side system must be check by pressure gauge manifold same after taking reading compare to rated hi lo pressure from manual.if low pressur recharge.this should be done by qualified a/c technician on service center.regard and have a nice day
Posted on Mar 31, 2009
  • 16 Answers
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Posted on Jun 07, 2009
  • 52 Answers
SOURCE: I have a Goldstar window unit 6500 BTU it has Cool, Fan, and Dry
in all honesty, it's a ridiculous gimmick. the system still runs the same as it would when you are using the A/C, however in Dry Mode there is a small heater in the unit which runs also, to prevent the system from lowering your room's air temp. a/c's always dehumidify air anyway, so basically dry mode is like running a/c and heat at the same time. $$$$$$.
Posted on Jun 18, 2009
  • 548 Answers
SOURCE: What does the
Your AC removes humidity and cools the air, in Dry Mode it cools the air but does not remove the humidity as much, which is OK in a desert (Las Vegas, Arizona, etc.) but not good for caribbean with the high humidity
Posted on Sep 01, 2009
Is there any kinds of problems with this air conditioner
Here are some reviews and questions that have already been asked on Fixya. any appliance that is only used for a few months of the year and then rests for months is going to exhibit some problems eventually. Usually just a matter of getting an AC engineer to add some more refrigerant gas.
  • Amazon.com: Customer Reviews: Arctic King MWK-06CRN1 ... www.amazon.com/Arctic-King-MWK-06CRN1-BJ7-Window-Mounted/product... Find helpful customer reviews and review ratings for Arctic King MWK-06CRN1-BJ7 6,000 BTU Window Mounted Air Condit at ... COOL AIR coming out of the Artic King.
  • Amazon.com: Customer Reviews: Arctic King MWK-05CMN1 ... www.amazon.com/Arctic-King-MWK-05CMN1-BI7-Window-Mounted/product... Find helpful customer reviews and review ratings for Arctic King MWK-05CMN1-BI7 5,000 BTU Window Mounted Air Condit at Amazon.com. Read honest ... by Arctic King...
  • Review of my Arctic King 5,000 BTU Air Conditioner - YouTube www.youtube.com/watch?v=oaB2CPeZLTs
    • BY GOLDENSONIC08
    • 7 MIN
    • 20K VIEWS
    2014-06-09 · Video embedded · Just a quick review of my Arctic King WWK-05CRN1-BI7 5,000 BTU air conditioner.
  • Arctic King 10,000 BTU Energy Star Window Mount Air ... https://jet.com/product/Artic-King-10000-BTU-HomeOffice-Window... This Arctic King Air Conditioner is designed to be installed in a standard double ... This 10,000 BTU window mount Arctic King Air Conditioner is one of the most ...
  • How to Repair Window AC ' eBay www.ebay.com > ... > Heating, Cooling & Air > Air Conditioners A window-mounted air conditioning unit can be a lifesaver for anyone in ... How to Repair Window AC. ... Arctic King 8,000 BTU Energy Star Window Room Air Conditioner ...
  • ACE Artic King Window Mount Air Conditioner 5,000 BTU ... www.fixya.com > Forum > Air Conditioners > ACE Recent ACE Artic King Window Mount Air Conditioner 5,000 BTU Model MWK-05CMN1-B, 1 ea questions, problems & answers. Free expert DIY tips, support, ...
  • ACE Air Conditioner Problem Support, Troubleshooting Help ... www.fixya.com > Forum > Air Conditioners ... Manuals & Customer Service for ACE Air Conditioners. ... ACE Artic King Window Mount Air Conditioner 5,000 BTU Model MWK ... ACE Artic King Window Mount Air...
  • Jun 09, 2016 | ACE Artic King Window Mount Air...
    How to quite a very loud fan
    clean wheels lube bearings
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
    Aug 15, 2014 | Goldstar GWHD5000 5,000 BTU Window Air...
    How do i connect a drainage tub to the back of r5050 goldstar airconditioner
    most small a/c threw the wall unit use evap condensate water to sling over to cool condenser but a three sided pan can be used to catch excess condensate water will have to be fabricated, use caution when mounting refrigerant tubing threw out that area.
    Aug 15, 2014 | Goldstar R5050 5,000-btu Air Conditioner
    Fan does not spin on a 5,000 btu unit? Used
    Do something to try to move the fan. If it's stuck - do something to get some silicone spray inside the motor shafts where they enter the motor. I have used straws, small tubing, and sometime can direct the can towards the shaft bearings. I can't see that this is not the problem except the on/off switch or such has a bad connection. WD40 spray will cut corrosion. lol
    I
    Sep 10, 2013 | Goldstar Heating & Cooling
    Water comes out the top and the fan makes noise
    drain line clogged unit not level
    Aug 23, 2013 | Goldstar GWHD5000 5,000 BTU Window Air...
    Air conditioner has no power
    check power source
    Aug 08, 2013 | Goldstar GWHD5000 5,000 BTU Window Air...
    HI there, I have a Goldstar WG1205R 12000 BTU window air conditioner that has no filter, blows slightly cool air and the fan power is very weak for 12000 BTU's How can I improve the performance of...
    Sounds like you have a 220 volt air conditioner plugged into a 120 volt outlet.This will cause the conditions you are describing.
    Put a filter on it please.
    Jul 10, 2011 | Goldstar Heating & Cooling
    Jun 11, 2009 | Goldstar Heating & Cooling
    GOLDSTAR AIR CONDICION (WALL UNIT) MODEL # BG8000ERY3
    Download it from the manufacture webpage and the model #.
    Sep 04, 2008 | Goldstar Heating & Cooling
    Goldstar WG5000 Air Conditioner Logo
    524 people viewed this question
    Top Goldstar Heating & Cooling Experts
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Bill Long
    Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
