Question about Homelite Leaf Vac Attack
Homelite Vac Attack II blower, won`t start
Before blower completly quit running when pumping primer bulb gas would run out carb and run rough. Then would not start . Upon pouring small amount of gas into carb blower would start briefly and then stall out. Replaced fuel, fuel lines, cleaned spark plug. Checked primer bulb for cracks. I have tried to stay away from this Ethanol gas as much as possible.
    Brigadier General:
  • 3,917 Answers
Thanks for writing to Fixya.com.
It seems you need to check the composition of the oil first.
One quarter fuel: three fourth ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends. If properly adjusted your blower will operate fine on 50:1 .Might find it varying from manuals but that’s fine.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on May 28, 2010
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
I have run my Homelite Vac Attack ii using gasoline only. Now it wont run.
You need to take to shop and have them check it out, more than likely the cost of Repairs will exceed the price of a new Blower, In other words Yes this Motor is NO GOOD . Sorry For the Bad News..
Oct 23, 2011 | Homelite Leaf Vac Attack
I have a handheld blower/vac: The primer bulb is new and will not pump fuel,not even fill the bulb. I checked the fuel lines to make sure they were correct.(homelite)
I was working on a neighbor's homelite chainsaw and I replaced the primer bulb, it was not intuitive, and I hooked up the lines backwards. Also if you are replacing the primer bulb, maybe you have old fuel lines that are deteriorating and need replaced. Did you check the in tank fuel filter? If it looks dark, it may be time to change it.
I hope this helps get you going again.
Sep 01, 2011 | Homelite Consumer Products MightyLite...
Primer bulb on Yardboss blower will not **** fuel from tank. Blower will run if primed manually.
remove your carb and clean it and replace diaphram's and needle , they tend to swell up from ethanol that is used in the gas now a days, and the diaphrams turn stiff and won't pump fuel. then put fresh gas in when you are done and also replace fuel lines and filter too., probably primer to because once it is hit with carb clean it just crumbles, good luck
Jul 31, 2011 | Homelite Consumer Products MightyLite...
MY homelite BP-240 backpack blower will not run with out the assist of starting fluid. First I tried to start it with just pushing the gas primer bulb. after no success I just sprayed start fluid . It will...
dont spray starting fluid in there to start it has to have a gas oil mix for the piston to have lubrication it will scar or burn the piston and cylinder wall check the fuel lines to see if they need replaced and the fuel filter also the priming buld to for cracks etc.
May 18, 2011 | Homelite Consumer Products Backpack...
I have a Homelite VAC Attack II that dies when you increase the throttle after it has warmed up for about 5 minutes. Any ideas?
Sounds as if its running out of petrol to the carb,have you checked for dirt in the tank,and or carb,failing that,you may need a new carb kit ,diaphram etc,they are available on ebay,rgds
Sep 26, 2010 | Homelite Leaf Vac Attack
My Homelite Vac Attack II is 4 years old and I
fit new pump ad float diaphragms in the carby
the fuel mix has become irrelevant as Stihl have an oil that is a 50:1 oil and covers all ratios and mixtures
do not use any e-mix fuels as that destroys carby components
Aug 09, 2017 | Homelite Leaf Vac Attack
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Homelite Leaf Vac Attack Logo
969 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
