Question about Tec Patio II Grill
The ignitor sparks but the pilot light doesn't light. Can this be fixed? (Tec Patio II Grill)
I have the same problem with my 12 year old Tech Patio II. Have you found a solution? I will call the manufacturer myself to see if they can help. They are most helpful.
Leslie
Posted on Sep 06, 2010
When was my TEC II made
From various reviews from folks who own the Patio II, I'm guessing 1998-2000. I have a Patio I that was purchased in 1996. It just died and I purchased a used Patio II so I have been researching this model. Also, found some videos on Youtube from repairing/rebuilding to how to cook on one.
Jun 18, 2012 | Tec Patio II Grill
I own the TEC Patio II Grill. I am replacing the ignitor switch. Where do i attach the wire for this unit. It did not come with instructions. Thank you, ML
If you removed the old one, all you need to do, is match the connection of the wire(s) to the old Igniter Module. There should only be one or two wires.
If you have misplaced your Owner;s Manual, I have provided a link.to it, that you can download & print for future reference. http://www.appliancefactoryparts.com/content/pdfs/126280-1.pdf
I hope this helps you and thanks for choosing FixYa. Happy Grilling!!
Aug 26, 2011 | Tec Patio II Grill
TEC Sterling II, Pilot light not lighting ceramic burners. Got new ignitor. It does create a spark but it doesn't jump to the pilot light or to the burners.
The gas may not be reaching the burners. Try match lighting a burner to see if it is. If it isn't do the following.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank. If you're using as 1 Lb
Canister tank. Turn the valve off and remove the canister.
2. Wait 5 minutes and reconnect the hose to the tank. Reinsert the canister.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. Or you will have to replace the Canister Assembly. For that you'll have to go to Tec Grills. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 08, 2011 | Tec Sterling II Grill
How do i replace the ignitor electrode, the place where the wire attaches has rusted off so I need to order and replace them. I have a Sterling G-seriesFR tec infrared grill. thanks
Here's a link to where you can find all that you need, as far as parts and the Owners' Manual, which will show you how to replace the ignitor electrode.
http://www.appliancefactoryparts.com/gasgrillparts/brands/tec/
Hope this helped you. Please let me know & Happy Grilling.
Jun 20, 2011 | Tec Patio II Grill
How do I connect the wiring to my igniter switch on a patio 2 Tec grill?
Hi, You will need to remove the front face plate. There are 4 phillips head screws holding the face plate on - one in each corner. Remove the screws wth a #2 phillps head screw driver. Once the face plate is removed you will have access to the orange pilot assembly wire. Simple plug the orange wire into the igniter on the face plate. Bolt the face plate back in place.
With your gas supply off - turn your rotary ignter and make sure there is a spark present at the pilot assembly.
GrillTechs,LLC
customercare@grilltechs.com
Nov 06, 2010 | Tec Patio II Grill
My Tec Patio II grill will not stay lit. The pilot burner works but the tiles just woosh and go out. I use portable gas canisters. I would like to take it apart and clean the gas jets but need a...
It is not your Gas jets it is your burners they or clog or crack,When that happen too much air gets in there they go out Replace them and that will take car of your problem!
Aug 05, 2010 | Tec Patio II Grill
Right side burner failure on TEC Patio II
the mesh could be split or blocked burner needs cleaning .
May 17, 2010 | Tec Patio II Grill
Tec patio II--convert from propane to NG
You'll need part #P2CKLP-NT Now all you have to do is find yourself a local TEC dealer
Jul 21, 2008 | Tec Patio II Grill
Tec Patio II Grill Logo
300 people viewed this question
Top Tec Grilling Experts
Paul Carew
Treefrog15
Treefrog15
Gary Kenady
Gary Kenady
Are you a Tec Grilling Expert? Answer questions, earn points and help others
