Question about Microwave Ovens
The ice maker will not draw water to the tray. The inlet valve has been changed
  • dougyarn
    dougyarn May 27, 2010
    refrigerator will dispense water but no ice is produced. I changed the inlet valve and after two days, no ice. This is a Kenmore model# 10656532400
  • dougyarn
    dougyarn Jul 16, 2010
    Thanks, for the solution, TheMobilian! The modular change worked.
  • 8,220 Answers
An ice maker does all the makin, the harvestin, and the waterin, all by itself. It powers up the water valve when it needs a refill. It also waits patiently for ice to form, then it heats up the ice a tad so the motor can dump it out. Near the end of the harvest a fesh supply is issed by the ice maker control. How? Some of them are fancy and use on board intel to monitor the resistance change in the ice mold to determine if the correct amount of water is in the ice mold. Then it constantly monitors changes in the ice mold resistance to determine if ice has formed. Some have a predetermined time (7.5 secs) that can be tweaked a tad with a tiny screw.
Near the end of the cycle a probe rubs a copper plate and energizes the water valve. Yep it is the ice maker itself that calls for water.
More HERE
Posted on May 27, 2010
  • Dan Webster
    Dan Webster May 28, 2010
    I looked up your model number. You ice box uses a modular ice maker.
    If you can remove the main drive gear without breaking the shaft you can clean the copper
    plate and MAYBE get that puppy to go a tad longer. All of the modular ice makers are the same regardless of brand. TIP: Get a replacement from the home store and use your original ice maker harness which simply slides out after you release a locking tab.
  • Dan Webster
    Dan Webster Jul 16, 2010
    Cool! I love it when a plan comes together! Glad ye could GIT ER DID!
    Genius:
  • 1,400 Answers
Hello
Is the saddle valve open to let water into the inlet valve?
The saddle valve is the water line attached to a main water line under the sink or a cold water source.
  • 4 more comments
  • dougyarn
    Yes, the saddle valve is open. Because water get through the water dispenser at the front of the refrigerator.
  • dougyarn
    What other solutions do you have?
  • mpcheesman1
    mpcheesman1 May 27, 2010
    Water filter.clean?
  • mpcheesman1
    On some models it may take an hour or two for the ice maker to cycle to make the next batch of ice.
  • dougyarn
    It has been days and no ice is produced. Where is water filter? And the water dispenser works.
  • mpcheesman1
    Im out of ideas,so im going to unlock this question to someone else.
    Sorry i couldnt help.
Water does not come through the water pump at the bottom of the refrg
If water is getting to the water valve then either the valve is not getting power from the dispenser and ice maker or the valve isn't working and needs to be replaced.
Aug 26, 2011 | Microwave Ovens
Water is shooting straight into the ice container, and not into the ice trays. I had to turn it off b/c the ice tub was full of water.
Well I hope it is just a hose cause if it isnt it is your coils in your Icemaker . The water runs over the coils until it backs up to a switch (could be bad as well) shutting off the water so the cycle can begin to ice the water. So the most likely is the hose ,then the switch then the solenoid that shuts the water off. You can tesst the solenoid by exercising the shutoff arm on the ice maker to see if it does just that shut off. Let me know
Jun 23, 2011 | Microwave Ovens
I installed a new fridge filter and now my ice maker will not make ice.
Check the direction of the water flow for the filter, did you put it on backwards? Did you open the pep-**** to allow water to flow to the unit again? Did the ice-maker line freeze up when you were changing the filter. These are all things that are common mistakes when changing the filter. Check this things out and get back to me with an update...
Jun 14, 2011 | Microwave Ovens
Hi, I have a amana fridge with freezer on the bottom. It has an ice maker and water dispenser. The big problem is a buzzing noise comming from the fridge, it start aprox every 16 min and buzzes for 10...
The buzzing you hear is the water valve trying to run water to the icemaker. If there is no water going to the icemaker it will be going into cycles one after another. And when it does it adds heat into the freezer. Turn the ice maker off and see if the freezer gets colder.
May 20, 2011 | Microwave Ovens
My GE Monogram ZDIS15CSS ice maker fills the bin with water but does not pump water over the plate to produce ice. We did drain and shut unit down for 2 weeks and it would not start on our return. Can...
I would check the ice level sensor... it is shown on page 9 of this manual...
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60440.pdf
If the sensor thinks that the bin is full it will not do anything...
That is why that would be my first area of interest..
heatman101
Mar 24, 2011 | Microwave Ovens
Ice maker will not make ice
hELLO THERE:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Dec 29, 2010 | GE Microwave Ovens
Not making ice. water is getting to the water dispenser but don't know why it is not getting to the ice maker itself. how do i check it/repair it.
Hia and wl;ecome to FixYa, I am Kelly.
We really need a make and model number to provide you with specific unit applicable information but.... in general, here goes:
1. Ice makers must have a freezer temp below 16 Deg F. If there is an airflow problem in the freezer caused by a fan or ice build up the ice maker will no longer make ice.
2. The ice maker has a thermostat that controls the harvest and fill cycle. If the thermostat fails it will stop making ice.
3. There is a water valve in the back of the unit that has TWO electric solenoids on it. One for water in door and one for ice. If a solenoid fails it will stop providing water to the applicable function. I.e water in door or ice. You can briefly remove the fiberboard back cover to gain access to the water valve. Then switch the installed terminal connection between solenoids. Left to right or front to back depending on how it is mounted. Then try the water in door. If water flows to the ice maker when water in door switch is actuated then the solenoid for making ice is good and the probem is with the icemaker. (Reconect wires in original positions.)
Note that anytime you remove power from the unit you must wait 10 - 15 mintues before re-applying power so the coolant system can stabilze. Other wise the compressor will not start.
Here is a web link that will help most people troubleshoot ice maker problems:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The link above is pretty good.
There is a 48 page job aid also for whirlpool in door ice that is also a big help:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
This should help you find out why it is not making ice.
Thanks for choosing FixYa,
Kelly
Oct 26, 2010 | Microwave Ovens
Its brand new so i'm not sure how it should run. here are my questions and observations. 1. it hasn't stopped running for two days and its the loudest appliance in the kitchen. why? 2. the overflow...
Howdy. I'm guessing you have a new refridgerator with a built in ice maker. although I don't know what the overflow pump might be, the running water sound is likely the ice tray filling.
If the running water sound is continuous, then there is a problem and the water valve that supplies the fridge should be shut off. By now you have likely turned down the temp in the freezer section a little, so I will move on to tell you that the new fridges are mostly ridiculously loud and make as many as 30 different, unsettling noises. Many will even be so bold as to mention this in the user's guide. Ideally, once it has settled in, made its bucket full of ice and come down to happy temps, it will quiet down a little. All you can do is keep it as full as possible , as this helps it stay cold better and is more efficient.
I hope this helps some:)
Farmerbear
Aug 28, 2010 | Microwave Ovens
Isn't making a full tray of ice
You have a bad inlet valve located underneath the back panel. Cheap and easy to replace. Good luck Rate me!
Aug 22, 2010 | Microwave Ovens
Model # trt18GREW5 ice maker will not make ice, and no water flowing thru valve w/ water supply on and water tube to ice maker disconnected
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Water doesn't flow unless the ice maker calls for water which it does immediately after dumping the previous load of ice.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 18, 2009 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
