Question about Canon SmartBase MP360 All-In-One InkJet Printer
Alarm flashing and saying cover open. Have opened
Alarm flashing and saying cover open. Have opened and closed cover and can't solve problem
  • 96 Answers
Canon.com your close door switch has something stuck in it or it is broken
Posted on May 28, 2010
How can i fix Cover open Error message for canon multipass mp360
The message indicates that the printer door or the cover located on the top is not closed properly, so you need to re-open the door or the printer cover and close it accurately.
GuruAid.com
Mar 09, 2016 | Canon MultiPASS MP360 All-In-One InkJet...
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
My BMW 1 series keeps saying the bonnet is open when its not, and the alarm keeps flashing up on the dash. Any help?.
Check the bonnet pin (small switch that is pushed in and out by the bonnet opening and closing) which tells the computer if the bonnet is open or close, maybe its faulty or broken and the computer thinks the open is always open even though its closed.
Sep 29, 2011 | 2008 BMW 1 Series
The printer door is closed but says it is open
Hi
This is a false alarm. Anyways you can find a little opening on the left side of the printer under the top cover. See if anything is not tripping the switch. Try to trip the switch manually by pressing it with a small screw driver of a pen and this will solve the problem. If the printer works then you can inspect the top cover if a small plastic thing is broken which trips that switch when it is closed.
PLEASE RATE MY SOLUTION
Jul 06, 2011 | HP Deskjet 3845 InkJet Printer
Power lock remote control is not working to open and close the doors while burglar alarm light (armed) keeps on flashing. When any door is opened, sound keeps "on" to indicate problem. The...
Check under the hood. Often, there is a small switch that needs to be closed when the hood is shut. This switch sometimes comes loose and when the hood is closed the button is never pushed. Find the magic button and reattach it to it's mount so that the hood will press it when the hood is closed and that should solve the problem. This button works with the alarm system.
May 25, 2011 | 2001 Honda Accord
What does it mean when the alarm window says "inner cover is open"?
Closing the inner cover to clear error messages.
  1. Raise the Scanning Unit until it stops.
    (A) Press the Open Button to open the Paper Output Tray if it does not open automatically.
  2. Close the Inner Cover
  3. Close the Scanning Unit.
Nov 28, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon pixma ip4600 showing C610 error code...... How do i solve this please
The 6 flashes says that the inner cover is open, there is a switch on the right, inside that is pressed when the cover is closed. These switches fail quite often. You can try blowing canned air into the openings on the right side inside near the switch and opening and closing several times to clean the switch contacts, but this printer has no service or parts as it was exchanged for new during warranty and tossed after warranty runs out.
Feb 01, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Printer
The alarm lamp will flash for an error or for no paper or for low or no ink. The most likely problem is that you changed ink cartridges recently and left the little plastic inner cover open.
Open the paper tray at the bottom and look insideif you see a little plastic door open push it closed. If this is not the problem call Cannon at 1-800-828-4040.
Nov 12, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Muratec mfx-2000 error problems
please check the switch of mentioned cover may be it is abnormal or open and close the front cover or check may be there is one reset switch in your machine
Sep 26, 2007 | Muratec Copier
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
159 people viewed this question
old marine
old marine
