Question about Samsung CLX-3175FN Color Laser All-in-One Printer
How do i print when it says replace/install toner waste bin
  • 96 Answers
There is a bin in the bottom of the printer that will come out. Look at manual and you will find it.
Posted on May 28, 2010
Replace the wast toner for the samsung clx3175
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and still the message will not go. I have a stack of work to do and am stuck as to what to do next! Help please
Apr 01, 2014 | Samsung CLX-3175FN Color Laser All-in-One...
Magicolor 7300 print window says Ink/toner waste bin full! but it's new
The clear section of the waste toner box where that goes inside the machine check that area sensor located there might have toner on it so the printer thinks the waste toner box is full
Apr 16, 2012 | Minolta magicolor 7300 Laser Printer
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and replaced it and still the message will not go. I have a stack...
open the cover and now remove the waist toner container (you say it is empty) check the conection to the drum unit sometimes if the waist toner is verry full there is a pille of toner closing this connection, now clean it and all the sorounding from the toner and mount the waist container back in his possition, close the front cover and try, it should work now.
Apr 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I have just replaced my imaging unit - now it wants me to replace/install waste toner bin
When the life span of the waste toner container has expired or it's full, the smart panel program window appears on the computer, indicating the waste toner container needs to be replaced. Otherwise your machine stops printing.
To replace it follow these instructions:
-Turn the machine off, then wait a few minutes for the machine to cool.
-Using the handle, completely open the front cover.
-Pull the waste toner container out of the machine using its handle.
-Remove the container's cap from the container, and use it to close the waste toner container opening. Do not tilt or turn over the container.
-Take a new waste toner container out of its package.
-Insert the new container into position and then push it to make sure that it is firmly seated in place.
-Close the front cover firmly. If the front cover is not completely closed, the machine will not operate. -Please make sure all toner cartridges are installed properly. If any toner cartridge is installed improperly, the front cover do not close.
-Turn the machine on.
Dec 17, 2010 | Samsung CLX-3175FN Printer
How to solve the problom of 'install/replace toner waste bin'?
Laser printers "print" by throwing toner onto a electrostatically-charged drum. The ink that sticks is then heated, and melts into the paper. The ink that does not stick falls into the "waste-bin".
Eventually, that waste-bin gets full, and needs to be removed, and emptied.
Aug 24, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Wont print
Usually with most samsung printers they have a toner waste bin in the printer. As you print, the waste toner dumps into this bin and fills up over time. Your printer manual may tell you where this is, but usually its right in the front of the printer when you open it up. It usually looks like a white or black plastic bin. There should be a plug on it that you can pop off and dump out the waste toner. After doing that put it back in your printer and it should get rid of the message.
Hope this helps :)
Apr 30, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Dell 1235cn Laser All-in One Printer - Waste Toner Bin issue
Wash it out with rubbing alcohol and let dry. Apparently there is a light sensor that will throw up this error if the bin is dirty.
Mar 09, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Printer LCD "Replace/Install Toner Waste Bin
I have just now, taken the waste toner bin out, squirted in some hand soap and water. Shook vigorously and rinsed it out. the CLX-3175 is working a treat again !
Sep 07, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
CLP 510 error
Sir,
Inside the front cover of the Samsung CLP-510 printer is a "Waste Toner Bin" - this bin collects any toner which is not fused to the paper during the printing process. The photo at the left shows the waste toner bin installed in its correct position.As you print, the waste toner bin "fills up" with wasted toner, and you have to replace it on a regular basis. Other printers send waste toner back to a separate compartment in the toner cartridge, however Samsung prefers to sell you and additional "consumable" - apparently the $130 cost of the toner cartridges (x4 cartridges = $520/refill) just isn't sufficent revenue.
In the photo below, we see the waste toner bin removed from its operating position, and lying down on the printer door - Just tipped down from its normal place.
Note (1) - this is an optical sensor which detects when the waste toner bin is full - A "bump" on the bin (2) fits into the sensor notch when the bin is in position. An optical sensor looks though the "bump" and is supposed to detect when the toner reaches this level.
Note that one of the inlets for waste toner (3) is just above the sensor "bump" (when the bin is in it normal position). You can also see the round feed which goes into this hole, just above the sensor notch (1).
The problem occurs because the waste toner being injected into the bin "runs down the side" through the sensor "bump" - after a little while, this dirties the walls of the "bump", and although this is nowhere near as opaque as the actual toner, the sensor is sensitive enough to decide the bin is full and shuts down printing. In my opinion, this represents two fundamental flaws in the design:
  • The toner inlet should not be positioned such that toner entering the bin runs through the sensor area.
  • The optical sensor should not be so sensitive that a little dirt is detected as a full bin.
It is interesting to note that Samsung explicitly advises that you not empty and reuse the waste toner bin - The overly sensitive sensor pretty much guarantees that you cannot do this, as it is virtually impossible to empty the bin without getting toner into the sensor bump, after which the printer will refuse to print and direct you to replace the bin.
The Cure The first time this happened, I noted the dirty sensor notch and cleaned the area - It lasted only for a few pages, at which time I contacted Samsung to report the problem - No matter how I tried to explain the situation to them (over several days of correspondance) the only response I could get from them was "the bin must be full - change it".The new bin lasted for perhaps 100 pages, at which point the dreaded "replace waste toner bin" message appeared. Samsumg responded that I should clean the external sensor (I had advised them that I had tried cleaning the external sensor in my first contact with them).
TO DATE - SAMSUNG HAS REFUSED TO ACKNOWLEGE THAT THERE IS A PROBLEM IN THE DESIGN OF THE WASTE TONER SYSTEM.
To confirm my theory that toner entering the bin via the inlet was dirtying the sensor area, I added a baffle made from tape as shown on the left - This cured the problem - Note how dirty the tape has become! (It WAS clear tape)... a LOT of toner was passing through this area!
Worried that the hot toner might melt/burn the tape baffle, I have since replaced it with one made from aluminum foil - Using only a single layer, with a fairly thin part that passes through the hole and is taped in place on the outside. It is important to get the part passing through the hole to be as flat against the side as possible, as it has to fit in beside the inlet from the printer - too much thickness or wrinkles here could cause a messey leak. It is also important that the baffle NOT be so long that it would prevent the sensor notch from filling from the bottom - this could cause the printer to overflow the bin - which would not be good... I recommend that you check the waste toner bin every time you change a toner cartridge.
This link will be useful.check out the link....
https://www.office.xerox.com/partners/products/Phaser6100/Phaser6100Series.html
Don't forget to rate the solution
Good luck
Mar 11, 2008 | Samsung CLP-510 Laser Printer
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
523 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
