Question about Fujitsu Siemens Pocket Loox N520 Pocket PC
FS N520 - weak GPS/ Satellite signal
Hello mates,
I have a FS N520 PDA, originally shipped with WM5 in German.
I had many issues with the GPS/Satellite signal, very long time (like an hour…) to get a fix.
I’ve upgraded the device ROM on to WM6 in English.
But I’m still facing the same issue, no satellite signal…
I’ve read a little about it on the net, and followed some forum notes.
I’ve installed the Firmware upgrade for the GPS chip and I’ve installed the recommended software by FS, called GPS locate.
Yet – still NO satellite signal!
The IGO application finds the GPS (configured under COM 8 bound 57600)
Did couple of hard reset (one was needed for the GPS chip firmware update)
I’m loosing my hope, ever to use this GPS PDA.
Any chance any of you guys knows the magic that will make the GPS works?
Thanks!
  • Ingabo May 16, 2008
    Mine has never worked. Since I had a garmin I never cared but now when I want to sell it I am looking for a fix. I still use the original English WM5 installation. Done no upgrades so ever. I would also like to see a solution to the problem !
  • Anonymous May 22, 2009
    I think that the GPS update screwed the chip..
    I suggest to consult with FJS support center
SOURCE:
SOURCE: Communication Timeout
Under connection settings switch off the "beam" - apparently there is a conflict between the IR beam port and one of the ports used by the GPS system. Has worked for me.
Posted on Nov 22, 2007
trintek
  • 111 Answers
SOURCE: will not fire up a gps signal
if you are having a problem with satellite acquisition, thats relatively normal for this unit, the antenna is buried in the thing instead of being exposed. if it is picking up satellites at all, then at least the gps chip and interface is functional. i would recommend buying an external antenna for times when you really need it.
if in the u.k., you can pick one up here
otherwise, do a search on ebay for "loox 520 gps antenna" or "loox 5xx antenna"
SOURCE: upgrading to windows moble 6
The following link has all of the files and instructions you need to upgrade your BlackJack to WM6:
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?SITE_ID=22&PG_ID=557&PROD_SUB_ID=558&PROD_ID=751&AT_ID=83176
You'll be glad that you updated!
Posted on Jan 26, 2008
  • 2427 Answers
SOURCE: PDA now doesn't pickup GPS satellites;when it did I couldn't access map charting software
Set Baud to 57600
Posted on Jan 27, 2008
SOURCE: Imate PDAL Upgrade
http://forum.xda-developers.com/showthread.php?t=460291
Posted on Jan 02, 2009
Does not pick up satellite signals
The gps device is not receiving signal simply because the strength to receive signal is weak. What you have to do is to reset the gps device by holding the power button for about 15 seconds or there about, then you release it when the gps restarts. It will acquire signal after resetting the device.If it does not acquire satellite signal. You can also try to use the gps in an open space where the gps will be facing the sky, if it does not, then you replace the antenna of the gps device.
Hope this information helped.
Jan 01, 2011 | Magellan GPS 320 GPS Receiver
My tn30 the sattelite signal is to weak
I may be able to help you improver your Motonav TN30 satellite reception.
Satellite reception is one of the issues addressed in Motonav TN30 firmware updates.
These Fixya Tips describe how to download and install the firmware for your Motonav TN30:
Motonav TN30 Firmware Fix
Motonav TN30 Upgrade Manual
I hope that helps.
______________________________________
Motorola Motonav TN30 Manual Download
Apr 16, 2010 | Motorola Mobility Motonav TN30 Car GPS...
GPS wont aquire a satellite
    Hello there and happy new year
    If Your Unit Cannot Acquire Satellite Signals
  1. For your Garmin GPS unit to acquire the satellite signals it needs to function properly, the unit must be taken outside, away from mountains, tall buildings and heavy foliage where it can get a clear view of the sky. Keep the unit stationary for several minutes while the GPS unit acquires the necessary satellite signals.It may take several minutes for the unit to locate a good solid signal
  2. OK
  3. Hope this is very helpful please keep me posted on this ok?
    Best regards Michael
Jan 01, 2010 | Garmin MAP76 handheldS GPS Receiver
GPS Lost Signal for a few months
This is taken from the Nextar Support Web Site;
Q: NOTICE for all US customers with M3 and Q4 series that have been having a problem recently with receiving a satellite signal.
A: Recently it has come to our attention that there has been a problem with a US GPS satellite, in the early morning of June 14 launch a sudden change in the code signal, leading to some GPS signal anomalies. It is told that the satellite signal should be running properly by June 22, 2009.
Jun 23, 2009 | Nextar Q4-04 Car GPS Receiver
Hi there, I Like to upgrade in my I-Mate JAQ OS WM 5 TO OS WM 6,1 or 6,5 if its is possible.Please show me how to do this. Thank you, Aleksandar
Hi, I'm afraid there is no offical or unoffical ROM upgrade for your PDA yet (ROM is the place where the PocketPC operating system is stored, and each device model has a different ROM so sadly you cannot use any other Windows Mobile 6 ROMs with your device.). I am giving more details about this issue to make it clear. Still you can follow the forums time to time to check if someone makes a ROM for your PDA. Basic problem is unlike most of the PDAs, your PDA is a non-HTC based PDA. I hope this helps. You can still download some PDA software to use your device more efficiently (Most of the PDA softwares are designed for working on both WM5 and WM6, since your device uses WM5, you won't be having a problem.).
Details of your PDA: (http://www.pdadb.net/index.php?m=specs&id=587&view=1)
Unoffical ROM forum: (http://forum.xda-developers.com/showthread.php?t=349007)
Offical ROM website: (https://www.imate.com/Support_DeviceSupport.aspx?key=48fc9a97-1b91-4350-919d-b4dfdbcb6cbd&cmd=roms)
Apr 18, 2009 | i-mate JAQ Pocket PC
Installing WM5 on Imate JAM
hello bro, i want to know whether i can install windows mobile 5 on my imate JAM. if yes from where i can find the WM5 file...?
Aug 21, 2008 | i-mate JAM Pocket PC
Yakumo delta 300 gps
I have the english manual for Yakumo 300 Delta GPS. However, if you have the german version of the PDA you cannot change the language - you need to get an English version of Windows and install it.
The manual is a 3,52 mb pdf-file. Drop me a line if you want med to mail it. [email protected]
Dec 03, 2007 | YAKUMO Computer Products Delta 300
Oct 26, 2007 | Fujitsu Siemens Pocket Loox N520 Pocket PC
Rx3715 several problems
If you have only flashed the English ROM, not any other language ROMs, read the following paragraphs. If you have flashed other language ROMs but not the German one try flashing the German one instead, there is something about it that clears the ppc out better. If you have flashed the German one, do not read on, as it will be an insult to your intelligence.
Most problems can be fixed with a ROM correction. Unfortunately, this is unachievable by simple re-flashing the English ROM. Certain other versions of the ROM (usually German is used) contain different enough sets of code (possibly different firmware?) to force the ppc to truly reset, unlike what happens when simply flashing the US ROM or changing to ROMS that use similar enough coding. Try flashing the German ROM and THEN reverting to the English. This tends to solve most any major iPaq issue.
Refer to
http://www.fixya.com/support/t395941-display_operating_difficulties
For full instruction.
Jan 26, 2007 | HP iPAQ RX3715 Pocket PC
Fujitsu Siemens Pocket Loox N520 Pocket PC Logo
351 people viewed this question
Top Fujitsu Computers & Internet Experts
Ekse
Alun Cox
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
