Question about Kenwood KDC-S2009
No sound when i hooked up the receiver, I have power, the tuner stays on a clear station, but I get no output from the speaker wires. The speakers work. what's next?
    President:
  • 676 Answers
Be sure to rn new wire to speakers. Depending on vehicle you are installing them in, it may have a factory amplifier. I can try to help you with this if you please tell me your year, make, and model of your vehicle. Thank you.
Posted on May 27, 2010
I have a protechnik pt- 625 7.1ch surround receiver amp. Dont know how to hook up in back i have cord but sound doesnt come out for the small
Hook the input interconnects betwn source RCA out connectors to Receiver in connectors and the speaker interconnects betwn the Speakers and Receiver , from the remote or the Receiver front select the appropriate input set the environment etc ., . IF YOU FIND ALL OF THIS to be too Technical just Connect speakers power-up the receiver select the Tuner Function and tune-in to any station to hear the radio play.
Jun 24, 2015 | Audio Players & Recorders
I think my receiver just blew. hissing noise from all speakers, now i get no sound - but the display still works...help
unplug the receiver, Everything- speakers, input/outputs. The only cord to the device left should be the power cord.
Power up the receiver, set the tuner on a strong station. check sound quality with headphones only.
If that was ok, now pick one speaker to test all channels with. Follow the procedure above with the
speaker. check each output channel with the tuner as a source using the one speaker. Good Luck!
Sep 03, 2011 | Kenwood VR-8050 6.1 Channels Receiver
Cannot get sound out of the system
Was everything working before you connected the new blue ray? Start by trouble shooting the receiver by starting over. Unplug everything except speakers. Switch to FM tuner, tune in a local station and see if you get any sound. Be sure you have the correct A or B speakers selected. This unit also has different sound options and default should be on "2 way" so only the two front speakers are to receive a signal.
If you get nothing, turn the volume to max and let us know if you get even a faint buzz. Follow up with results.
Jul 01, 2010 | Denon AVR-87 Receiver
The phono works, but i get no sound when tuner on
This usually means that the tuner is not getting sufficient reception for the station you are trying to listen to.
Receivers come with cheap wire loop antennas try upgrading to a powered FM antenna available online or at your local Radio Shack.
Hope that helps
Feb 15, 2010 | Pioneer VSX-D903S Receiver
My Sony STR-DG500 wont turn on just clicks once and nothing.
Sounds like faulty psu (pwer suply unit) Amp is going into protection mode. Disconnected all speaker and av wires (only power) turn up volume and see if it stays on. If not psu, sounboard or volume function faulty. If on, connect one speaker L or R. Go to tuner mode to tuned radio station an listen for sounds. If on, connect speakers and av cables one by one and test each one on its own until amp switches off, Investigate from there were problem is. Make sure speakerwires is not shorting out.
Aug 29, 2009 | Sony STR-DG500 Receiver
No sounds
Test one speakers at other amp to ensure its working. Amp is going into probable protection mode. Disconnected all speaker and av wires (only power) turn up volume and see if it stays on. If not sounboard or volume function faulty. If on, connect one speaker L or R. Go to tuner mode to tuned radio station an listen for sounds. If sound connect speakers and av cables one by one and test each one on its own until amp switches off, or no volume. Investigate from there were prolem is.
Feb 25, 2009 | Pioneer VSX-D710S Receiver
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Mar 27, 2008 | Alpine CDA-7876RB CD Player
Receiver amp problem?
You are having problems with you audio amps, 1 or more are going out. will need to change using part number on amps. you can order from, Bluestar-online.***, VanceBaldwin.***
Oct 04, 2007 | Audio Players & Recorders
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
