Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60 No Power coming on TV. Red light does not illuminate either.
  • PHD1027 Apr 28, 2008
    Had tv looked at and they said one of the tubes leaked onto something and shorted out. It started off with no picture but had sound. tv was left on then no power at all.
  • kekaulamoku Apr 30, 2008
    I HAVE THE SAME PROBLEM. WHEN I LOOKED IN THE BACK THE FUSE WAS BLOWN. IREPLACED THE FUSE AND THE TV WORKED FOR A BIT. THEN IT WENT OUT AGAIN. THEN I WIGGLED THE FUSE TO TRY AND SEE IF THAT WOULD DO IT. THE TV TURNED ON THEN SHUT DOWN IN 15 MINUTES. I NEED TO KNOW IF ITS A PROBLEM WITH MY POWER BOARD OR NOT. I HAVE CALLED PROFFESIONALS FOR ADVICE AND 2 OF THE THREE HAVE SAID THAT IT COULD BE THE PROBLEM. THE OTHER ONE, NO COMMENT!
On power on tv
Posted on Apr 13, 2008
SOURCE:
Why is my screen red when it should be black?
Search Results
    Philips Magnavox 8p6031c Crt Lens Fluid Repair Questions ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/page-11
    Recent Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & answers. Free expert ... Philips flat screen tv, Red flashing light. Light.
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Repair ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/popular
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & fixes. ... My son accidentally spilled water on our Philips tv and when i turned it on ... I need a screen replacement of philips tv 60" ... Why the tv come on but a min after the red blinking come on an it turn off by it self what the problem?
    Magnavox Projection TV problem... ' Techlore
    www.techlore.com/forum/thread/.../magnavox-projection-tv-problem
Jan 13, 2016 | Philips Magnavox 8p6031c Crt Lens Fluid...
I have a 42 inch philips lcd tv and it will not turn on. Tried unplugging it for 60 seconds and only the light will blink red sometimes and then blue sometimes. Do I change out the power source
Number of TV have a bad batch of capacitors on the power board. If you look like split mushrooms that is a bad sign. But there are kits if you know how to solder.
Oct 25, 2015 | Philips 42PFL7403D/F7 42-Inch 1920 x 1080p...
The TV normally has a green light illuminated in the lower left. Now there is a red blinking light (7 times) and the TV is not responding to any TV buttons or remote commands. If I unplug and plug back in,...
Philips Televisions are legendary for having faulty power supply capacitors.
In order to prevent really bad things from happening, the TV does a two-stage power-on. It first does a basic diagnostic test, and if that fails, it stops it from going any further.
Philips tends to use cheap capacitors, use capacitors that are somewhat under-sized for the job, and also seems to be pretty bad at soldering.
Personally I've got my Philips LCD TV opened up on my workbench for that exact problem.
Most repair shops would replace the whole power supply board ($150-200 part plus labor), while most DIY fixers take a stab at replacing the obviously bulging and failed caps for less than $10.
Oct 07, 2009 | Philips 42PF9630A 42 in. Plasma Television
Philips 60P8342
Iam looking for this part 313501707611 it's that board brook
Dec 19, 2007 | Philips 60P8341 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
