Question about Lasko 1820 Stand (Pedestal) Fan
The fan blades are hitting the back of the cage
Last night, the fan began to hit the back of the cage. I attempted to fix the problem, but I am unsure as to why it is happening. I cleaned the fan blade, thinking it might be off balance and re-tightened it on the flywheel. It was silent for about five minutes and began to hit the rear cage again.
  • 394 Answers
Just a suggestion. Make sure the back part of the cage is securely fastened to the motor housing. Good Luck,
Wayne
Posted on May 27, 2010
Coleman RV Rooftop Air Conditioner - cage fan making a noise like it is hitting on something as it goes around. The motor works as it should, low and high fan and cool, the air is cold. The only thing...
Those squirrel cage fans have a habit of coming apart, or getting dirt in them and going out of balance...then they wobble and hit the sides of the fan housing...
Make sure the fan is clean and also move it around a bit to make sure it is not coming apart....
Often the only way to fix them is too replace the sqirrel cage part...
heatman101
Mar 06, 2011 | Dometic Rooftop RV Air Conditioner
My computer when turned on is making a big rattling sound. What is wrong with the computer and how can I fix it?
Sounds like something is loose and is hitting the fan blades.
Remove the cover and check the cables near the fan, tie the cables back and make sure they don't hit the fan blades.
Sep 20, 2010 | Computers & Internet
Sounds like when you put sneekers in a dryer?
Sounds as if one of the two fan blades is hitting the housing of the unit. May need to removeunit after unplugging and visually inspect squirell cage and outer fan blade. May need to resecure/ Good luck
Jul 13, 2009 | Goldstar KG6000R Window Air Conditioner
I hit a deer the other day. I replaced the
try turning on the a/c, if the fan comes on your good to go
Jun 30, 2009 | 2000 Dodge Caravan
The fan on this AC broke for some reason. The blades flew out of the AC. Can this be fixed? If so, how? How much for new fan?
outdoor fan if it hit your condenser coil your toast, if its indoor blower (squirrel cage) lets say about $500- $700 if you have pro do your work. have a pro do it NATE certified
May 23, 2009 | Heating & Cooling
Bad fan noise from convection oven
THE ROD THAT HOLDS THE FAN BLADE IN PLACE IS WARPED BENT OR LOSE SOUNDS LIKE YOU BOUGHT IT THAT WAY EASY FIX! ORDER PART AND DO YOURSELF
Nov 16, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Grinding of fan
There should be a black round nut in front of the blades in the very center. It will have ribs on it so you can grab it. Turn it Counter clockwise, and it should unscrew.
Then you can remove the blade assembly and get to the back cage to tighen the screws.
This should take care of the problem.
Re assemble in reverse order.
Let me know if you have any more questions or if this doesnt work.
Good luck.
Mac
Aug 19, 2008 | Holmes Products HASF1516 Stand (Pedestal)...
Laser 72 exhaust blower noise
the combustion blower sucks in clean air so it has no place in the exhaust stream. hence no carbon build up. the blades of it look like a vacuum disk on a vacuum cleaner. if the fan was recently rebuilt, make sure of the placement of the bushings. if one is misplaced the fan will rub on its housing and make all kinds of racket.
Dec 16, 2007 | Rinnai Toyostove Direct Vent Heater:...
Amana bottom refrigerater
huthy, the fact that it's lasting 15 to 20 seconds leads me to believe that it could be one of the fan blades hitting. The valve springs on the compresser would make more of a clunk-clunk noise and wouldn't last that long. The evaporator fan in the freezer compartment has a grille that will snap on and off, clip on the bottom and tabs on the side. See if you can remove the grill and check to see if there is any ice build up around the evap. fan. The other fan, condensor is in back by the compressor, it could be hitting on the shroud upon start up or shut down. Check these things first and post back...Catriver
Mar 20, 2007 | Amana ABB1927DE Bottom Freezer...
Lasko 1820 Stand (Pedestal) Fan Logo
202 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
