Question about LG Vu CU920 Cellular Phone
Low battery all the time - LG Vu CU920 Cellular Phone
    Master:
  • LG Master
  • 443 Answers
LEO Privacy is small in mobile phone, but it has many features: fast charging screen, locks apps and boosts the phone. Very efficient to speed up your phone and keeps snoopers out. LEO Privacy Applock Hide Safe Android Apps on Google Play
Posted on Nov 30, 2016
  • 484 Answers
the fact that your battery indicates low all the time is as a result of either the battery or the phone.
to check if it is the battery, try another battery in your phone to see if it last longer,. if it does then the fault is from the battery and it needs be replaced.
to check if it is the phone, try another well charged battery in the phone to see how long it last. if it shows battery low on time, then the fault is from the phone. which is as a result of a problem on the board of the phone.
to solve that problem, it will require you to take the phone to an lg expert because it requires a careful and systematic process.
take care.
Posted on May 27, 2010
Simon XT "system low battery"
IT might be testing ok, but you need to load test it. It could be the charging circuit but in most cases the battery will show a surface charge that is ok for a short period of time.
Feb 10, 2014 | GE Security Simon Xt Wireless Control...
ATT-974 Low Battery incdicator
maybe the new battery is in stock for a long time. then it is in low power.(http://www.my-batteries.com/digital-camera-batteries/sony-np-fr1.htm)
Aug 03, 2012 | AT&T ATT-974 Corded Phone
Package, manuel and receipt were accidentally thrown away and we don't know how to charge the radios. They work, but are running low on battery power! They have a power supply cord that you plug both...
From what I just read on the Cobra website, you may be misinterpreting the battery indicator lights:
My radio keeps showing low batteries
This may simply be a matter of misinterpreting the low-battery indicator. We use two different types of battery indicators:
  1. Battery Level Indicator: This battery indicator is always visible, and has several segments. When all the segments are lit, the batteries are full. When only the last segment is lit, the batteries are almost exhausted.
  2. Low Battery Indicator: This type is usually NOT visible. It only appears when the batteries are low, at which time it flashes on the display to warn you of a low battery condition.
Please note that when you turn on your radio it first performs a display test. Everything on the display will light up for a few seconds, including the Low Battery Indicator. This does not mean that the batteries are low. After a few seconds the display test will end, at which time the Low Battery Indicator should go away.
Here is a link to the Manual for your radio:
https://www.cobra.com/downloads/manuals/PR260WX_MANL.pdf
It is a PDF file, which requires that you have Adobe Reader or equivalent installed on your computer for it to open and display properly. If you don't have it, it can be found here (it's free!):
http://get.adobe.com/reader/
Jul 16, 2011 | Cobra microTALK PR 260-2 WX Two Way Radio
I have the cobra CXT275 they have been on the desktop charger for 5 days. They won't charge over a 1/4 of the way how do I get the maximum charge?
Jan 12, 2011 | Cobra Two Way Radio
"JUMPED' time. Fixed. when started back up, it
This sounds like a low voltage issue. Check the system voltage while running, need 13.8 to 14.6 or so. Have the battery terminals cleaned and load test the battery. If the battery voltage drops too low during startup, that can cause the clock to loose it's time.
Nov 01, 2010 | 2006 Kia Sedona
Low battery alert at start up. must always type
The only battery in a desktop PC is the CMOS battery. This is a 10c sized silver disc that is held in a plastic black clip on the Motherboard. It can be clipped out and easily replaced. they are 3.6v and somewhere like Radio Shack etc. will have them.
Jan 27, 2010 | Dell Dimension 8400 PC Desktop
Low Battery warning on Simon 3 even when I changed it out
temperature affects batteries. if the batteries on the window sensors have been in use for some time it is probably time to change them. Alarm batteries are only expected to last 3 to 5 years with moderate use. If you have close neighbors or live in an apartment complex then false reads could be a factor.
Aug 11, 2009 | GE Security Simon 3 Wireless Home Security...
Nokia 8800 keeps switching off saying battery low.
sadly FIXYA can not , would recommend getting a replacement (NEW ) phone
May 13, 2017 | Nokia 8800 Cellular Phone
Low Battery
Dear sir, u need to clean the battery terminals/. Battery chemicals creates an internal circuitary & causes drain of batteryu at faster rate soem times 12 times faster than normal .. , best way to do is
open all screws , then wash the radio with iso-propyle alcohol..& a brush let it dry fully then assemble the same . I hope u will be able to get gud back up time .
REgards
raj
May 24, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
LG Vu CU920 Cellular Phone Logo
236 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
