Question about GE JES1384SF Microwave Oven
Microwave about 3 years old. Started making a bag of popcorn and after about 1 min. the unit started making a sizzling and grinding sound and a puff of smoke was noticed at the inside right panel opening. Immediately shut unit off. any ideas?
  • GE Master
  • 9,047 Answers
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the metal of the oven wall is burned or chipped, the area will first have to be sanded smooth and cleaned and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth, then apply paint.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
Posted on May 28, 2010
Over heating and shuting off
I am not surprised! Cloth of anysort is not recommended to be placed in a microwave oven!
That includes undies and socks which many try to speed the drying time of.
Regarding the popcorn.. The oven is overheating due to a possible containment in a hutch, where insufficient airflow is available to lower the temperature. Pull the unit away from the wall to allow more airflow, clean the vents and help it breathe.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
When I put a bag of popcorn in the microwave, it started but noticed it was making a funny noise so I stopped it and opened the door and there was a little bit of smoke coming from the side wall and it...
The first thing I would do is thoroughly clean the inside. Take particular care when cleaning around the upper left side. Sometimes a buildup of food steam or spray can cause the problem you are having. Never spray anything into the microwave, in an attempt to clean it.
Hope this helps.
Jan 20, 2010 | Bosch HMB402 Microwave Oven
OVERHEATING - Magic Chef Microwave M# MCO160S
Generic questions and comments:
Does your microwave have a "popcorn" setting and are you using it? Is there a rotating table in your machine? Is your popcorn bag elevated on top of a bowl or similar? Are you using some other "sensor" setting? Can you use straight time setting and get it to go past the 1 min 45 second mark?
On my microwave, it takes just about that much time and the popcorn is done ... BUT only if I elevate the bag to about the middle of the oven.
Let me know if this works for you.
a
Sep 21, 2009 | Microwave Ovens
Problem with GE Microwave Model JES1358WK 02
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
q
May 30, 2009 | GE JES1358 Microwave Oven
Viking professional vmoc205ss convection Cooking POPCORN
You need to use one of the metal racks that came with the Viking microwave to raise the popcorn bag off the bottom of the microwave. It works great!
Apr 06, 2009 | Microwave Ovens
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Noise/humming while cooking; especially popcorn; intermitent on other food
Popcorn is heated by a metallic insert in the bag. This causes some additional power consumption by the magnetron. It is no cause for alarm.
Dec 19, 2007 | Kenmore 80412 Microwave Oven
Microwave Panasonic NN-A554W
This is usually caused by either exposed metal in the micro, or the metal in the bag of popcorn was overexposed. Typically if this happened, replacing the door components costs around 20-50 bucks. Which in, in any case, if the unit is over 2 years old or older, it would be more fesable to replace the unit.
Sep 17, 2007 | Kenmore 63672 Convection/Microwave Oven
GE JES1384SF Microwave Oven Logo
94 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
