Question about Saeco Incanto Classic Espresso Machine
Water light blinking
After having the filling up the water tank I got the water indicator blinking. I've tried tapping on the water tank, cleaning it, etc but the water indicator doesn't stop blinking and the machine doesn't work. The manual does not make reference to this concern.Does this mean decalcifying is needed?
Thanks in advance for your help
  • polycarp372 Nov 28, 2008
    machine returned from service center. cannot prime. water light will not stop blinking. Water light is on and cannot turn off
  • 487 Answers
Ok you have a priming problem
press the warm water button and open the valve . Normally that should prime it.
Other wise you have in the box the primer tool of saeco.
Just press the button and push the water in after opening the knob.
give you details.
Posted on Apr 16, 2008
I need to know why the Hoover Max Extreme keeps telling me t check the tank?
Hi! The solution and water goes in the top tank. Dirty water is suctioned into the bottom tank as you're scrubbing your floors. To fill the clean water tank, remove the clean water tank cap. The cap serves as a measuring cap for the solution. Fill the cap with Hoover carpet washer solution to the fill line. Pour detergent into tank. Fill the rest of the clean water tank with hot tap water and twist the cap back on. You are now ready to clean. Hope this helps!
Aug 20, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Why standby light active and water tank fill light is blinking ?
It shouldn't harm it plus if the scale is affecting the switch for the watertank then it should sort it out....
Jul 25, 2014 | Bosch Tassimo TAS4011GB Coffee Maker
How much soap and water to mix for steam vac
Hi! To fill the solution and clean water tank, turn tank upside down and unscrew cap. Pour Hoover cleaning solution into tank to detergent fill line. Then fill tank completely with hot tap water. Hope this helps!
Jul 10, 2014 | Hoover F5505 SteamVac Spot Vacuum
Cannon MP990 C610 error
Inkjet cartridges dry up very soon. You have to use it everyday. Or clear the nozzles using hot tap water soak. Or try new cartridges again.
Apr 03, 2012 | Computers & Internet
How do i fill the water
There is a tank within a tank design on these deep cleaners. Use warm tap water and fill the inner bladder.
The Tank-in-Tank system is designed with a bladder inside for
clean water. As you clean, the bladder will empty. Dirty water
collects in the tank outside the bladder.
Apr 20, 2011 | Bissell 8910 ProHeat Clear View Upright...
How to clean waste tray
The printer uses an optical sensor to determine when the tank is full. There are clear plastic ports on the side of the tank that the light needs to penetrate in order for the printer to work, otherwise it will generate waste toner tank full error and stop printing.The easiest way to clean the waste toner tank, is to remove it from the printer, and dump the contents into a trashcan. Tap it a few times to get as much as you can. Then take some soap and water and partially fill the tank. Then take the green cap and place it over the tank opening. Shake the soapy water in the tank a few times to clean it. Then dump the soapy, toner water in the sink. Add some tap water into the tank and replace the cap and shake then drain. You don't need to get the tank completely clean, just enough to allow light to past through the clear plastic port. Dry the outside of the tank and and reinstall into the printer. Hope this helps you.
Dec 14, 2010 | Samsung CLP 300 Laser Printer
Blue light blinking, tank full, water not heating up
noavatar_s.gif rktcyntst
Rank: Apprentice
Rating: 0%, 0 votes
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 14, 2009 | Saeco Starbucks Sirena Espresso Machine
No instruction manual
1. Before filling the water tanks, push the POWER switch to the “OFF” position and
unplug unit. Refer to cleaning instructions.
2. Remove water tanks from base, turn each tank upside down and remove tank cap
by turning counterclockwise. Fill tank with clean cold tap water.
Replace the tank cap by turning clockwise. Tighten firmly.
3. Carefully pick up tank, since it will be heavy when full, and slippery if wet.
4. Place water tanks on base. Make sure tanks are properly placed, otherwise, the
humidifier will not work correctly.
Feb 11, 2009 | Slant Fin Cool Mist GF-220 Humidifier
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
Saeco Incanto Classic Espresso Machine Logo
415 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
