Question about Dell Ethernet Card Network Adapter
Windows 7 doesn't see network card after sleep
I upgraded a Dell Vostro from XP home to Windows 7. The ethernet card works fine until the computer goes into any power save mode. When the computer wakes, the OS does not see the card and you must physically unplug and re-plug the network cable. Sometimes even that doesn't work. I have downloaded the most recent driver from Intel but no luck. Can anyone help?
  • gggg May 27, 2010
    Is the most recent driver the Windows 7 driver?
    Genius:
  • 1,400 Answers
Hello
Go to control panel,system,device manager,network adapter,Right click on your adapter.
Then properties,power management.uncheck all power saver and wake options.
Posted on May 27, 2010
Can I clone a Windows XP hard drive from another computer and expect it to run on the Vostro 1000?
You can in a way, but you will need to download a lot of XP drivers from Dell to run XP on a Windows7 computer.
You can not just swipe out Windows7 for XP.
For better answers about this go to http://www.dslreports.com/forum/microsoft they will walk you through this.
Jan 22, 2016 | Dell Vostro 1000 Notebook
Dell Vostro 200 will not connect to internet, what can I do?
check that the lan connection isn't disabled.
go into control panel>network connections.
I would disable it and then re-enable it, that sometimes works. if there is no lan connection showing then you need to download it onto a usb stick from the dell website and install it on the vostro. Product Support Dell US
Apr 25, 2015 | Dell Vostro 200 Desktop Computer
Ethernet driver for windows 7
There does not seem to be a valid Windows 7 network driver:
http://ftp.dell.com/Pages/Drivers/dimension-3100.html#Network
You can try the driver for XP to see if that will work, otherwise you may need to buy a new NIC card.
Oct 14, 2013 | Dell Dimension 3100 PC Desktop
In order to configure TCP/IP,you must install and enable a network adapter card, Windows 7, Vostro Dell A840
Not much to go on with your question. Windows 7 does not see your network adapter(s). Did you just upgrade? If so, you might need to go back to Dell website and download the Win7 drivers for you laptop. On that laptop you should see 3 network interfaces for WiFi, Ethernet, and the modem, and possibly a 4th for bluetooth. Dell is pretty good with downloads - just type in your service code at their support site, and they will only show you what you might need for your computer.
Jun 09, 2010 | Dell Computers & Internet
I recently Upgraded from Windows XP to windows 7 when Windows 7 was finished intalling internet connection did not work. Before upgrading everything worked fine.I did troubleshooting and it said ''No...
Hi
Win 7 is extremely touchy about network drivers. I didn't see your computer model listed but you'll need to log onto your computer manufacturers support page and download the Win 7 drivers for the network. Since your internet connection doesn't work right now I'd suggest another machine, if you have one or go to your local library with a Flash Drive and download the drivers to that. Good Luck
Mar 07, 2010 | Microsoft Windows XP Media Center Edition...
I upgraded from win XP to Win 7 for my dell optiflex gx280. There were 3 problems that windows 7 couldn't detech the ethernet, video and sound drivers. I've tried installing the available drivers from...
just format the drive and install the os windows 7 again.. connect it to the internet while installing it.. once done with the installaion.. click on the volume icon on side tray.. it will search for the solution online and will automatically install the drivers.. i have the same model desktop and i am using win 7 with all working... good luck!!!
Nov 30, 2009 | Dell OptiPlex GX280 PC Desktop
Dell ethernet card
You must buy a pci spec'ed Ethernet care. This will fit into the white socket on the system worse case you go buy a USB based ethernet adapter.
Mar 19, 2009 | Dell Ethernet Card Network Adapter
Have a sony vaio pcv j120 that was purchased in 20001 7 nvr used
yes. it might be a good ideea to upgrade os, windows 2000 or windows xp. try to instal a new network card if you think that your nic is damaged. search for a new pci ethernet card.
Feb 22, 2009 | Sony VAIO PCV-J120 PC Desktop
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
I have the same network card.
Never had this problem with Vista (32 bit) but recently switched to Win7 (64 bit) and had the same problem as you.
I solved by going under Control Panel->hardware->network card properties->power save and unchecking "Allow pc to switch off the device to save power"
Jul 13, 2008 | Intel Ethernet 10/100 Network Adapter
Dell Ethernet Card Network Adapter Logo
301 people viewed this question
Alun Cox
