Question about Microwave Ovens
How to set it to high, med or low
Magic Chef MCO 153 UBF How do I set it to high, med or low? also the filters underneath look clogged with grease are these replaceable?
  • Microwave Ovens Master
  • 9,047 Answers
Grease filters can be cleaned, according to your manual.
If you've misplaced yours, it's online here.
Charcoal filters cannot be cleaned and must be repaired.
From the manual:
Reusable Grease Filters
The reusable grease filters should be cleaned at
least once a month. Never operate the
microwave without the filters in place. In
situations where flaming might occur on
surfaces below the hood, filters will stop the
entry of flames into the unit.
To Remove Grease Filter
To remove grease filter, grasp the “finger hold”
on the filter and slide to the rear. Then pull filter
downward and to the front. The filter will drop
out.
To clean Grease Filter
To clean grease filters, soak and then agitate
filter in solution of hot water and detergent. Do
not use ammonia or ammonia products because
they will darken the metal. Light brushing can
be used to remove embedded dirt. Rinse, shake
and remove moisture before replacing.
To Replace Grease Filter
To replace grease filter, slide the filter in the
frame slot on the back of the opening. Pull filter
upward and to the front to lock into place.
Posted on May 28, 2010
Mco 153s can not find how to access oven light for replacement there does not appear to be access from above under filter no door solid metal only
On page 20 of your owner's manual:
To replace oven light:
1. Disconnect power at main fuse or circuit breaker or pull plug.
2. Remove the top grill by taking out the 2 screws that hold it in place. (See Figures 3.)
3. Remove charcoal filter.
4. Pull out the Lamp cover. (See Figure 4.)
5. Replace the light bulb with a 30-watt bulb.
6. Replace light housing to original position
7. Replace charcoal filter.
8. Replace top grill and secure with screws.
9. Connect electrical power.
Aug 10, 2013 | Magic Chef Over The Range Microwave
I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
Dec 23, 2009 | Magic Chef CMV1000B Microwave Oven
Magic Chef MCO 153 UQ heats but doesnt' turn
You can still use it, but must be aware that this is a relatively high power microwave, so food will burn if it isn't turned.
Jul 28, 2009 | Magic Chef Microwave Ovens
Shuts down for 5 minutes
I have the same problem with my new magic cheff over the stove microwave oven. I call magic chef and they gave me the 800 number for the service center (1-800-775-0202). When I described the problem they told me to just put a plate under the popper and this wouldn't happen anymore. I haven't tried it yet but here's hoping.
Jan 15, 2009 | Magic Chef MCD1311ST Microwave Oven
Enamel under the glass turntable has flaked off
This is due to spills, accumulated moisture from steam / condensation, or both.
It can also be worse if your internal cooling fan is not running, or if the vents or filters are blocked or clogged.
Since the the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and then dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Let it dry overnight with the microwave door open.
Once that's done, you should occasionally look for accumulated moisture on the floor of the oven and keep it dry.
The model number tag should tell you where it was made.
Jan 07, 2009 | Magic Chef MCB780W Microwave Oven
I need a plate for my over the range microwave oven. model MCO 153 UWF I have been looking for one for several months now and becoming very frustrated.
You can order it online from Magic Chef.
If you'll visit here and select model MCO153UW from the first drop-down menu then select turntable tray from the seconds drop-down menu, you'll find part # 441X335A10.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 28, 2008 | Microwave Ovens
MICROWAVE WILL ONLY HEAT ON CERTAIN SETTINGS. how do i set the heating instructions?
I have a Magic Chef model MC0160UQ. Within 2-3 minutes of heating food it shuts off completely for about 5min. Also, when I select the low fan it does not work, however the high fan works. Please assist with these issues if possible. Am I able to fix or adjust the magnetron myself since it may be overheating? or what should i do?????
Jul 18, 2008 | Magic Chef CMV1000B Microwave Oven
Magic chef MCO 153UBF
Your owner's manual can be downloaded here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 07, 2008 | Magic Chef Microwave Ovens
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Sep 02, 2007 | Microwave Ovens
Microwave Ovens Logo
249 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
