Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John Deere 4500 Compact Tractor will not start
Turns over but will not catch. Seems to be locked out as result of safety feature requiring tractor be in neutral and seated (both of which are).
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
pic498
  • 32 Answers
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Posted on Jun 13, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
SOURCE: john deere 425 lawn tractor. it wont start but it
My John Deere did the same thing. Turned out to be the emergency brake sensor.
Posted on Jan 21, 2010
wireguy212
  • 1627 Answers
SOURCE: i need a wiring diagram for a john deere 4500
What are you trying to repair?What on the tractor is not working?Copy right laws prevent me from posting the diagrams but i can help you with your problem,i have access to the diagrams you need so let me know what you need.
Err 68 what it means and how too fix no fule too motor
Err 68 means
Err 68 Hold-in Relay ON. Output from the Display is short circuit. No fuel to the engine. Contact your John Deere dealer
Aug 24, 2014 | Cover My Tractor Tractor Cab-Enclosure for...
Where is the serial number for a john deere 4105 compact utility tractor and what do the numbers mean
follow the link to a picture of the location
http://www.greenpartstore.com/John-Deere-Model-4105-Compact-Utility-Tractor-Parts.html
Aug 23, 2014 | Garden
I have a 4500 John Deer tractor that typically won't start in cold temperatures (i.e. 39 or below) otherwise it starts promptly. I've pushed the key in to heat the glow plug a minute or more.
The 4500 John Deere tractor sounds like the glow plugs are not working. Checked voltage at the glow plugs to make sure that there is 12 DC volts.(Might have to remove main wire from the glow plugs to check!) If no voltage at glow plugs there maybe a bad fuse,relay or wire connection in the glow plug circuit. If there is 12 DC volts at the glow plugs, it is possible that the glow plugs need to be replaced.
Jan 01, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I need a wiring diagram for a john deere 4500 tractor
Jan 17, 2010 | John Deere 4000 201000-> Gas & Diesel...
Jun 09, 2009 | Diesel Garden
My john deere jx75 lawn mower won't start up.
There's a lot of safety features on tractors. Your owners manual would be the best place to check. I'll throw out a common spring time start up issue: dead battery. If you didn't have it on a trickle charger over the winter, tractor batteries die in 2 or 3 years. If it has started recently, check for a blown fuse.
For safety features, make sure you're sitting in the seat, brake on, clutch fully depressed, and any attachments (blades) disengaged.
May 02, 2009 | John Deere A,b,g Tractor Carburetor Float...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
321 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
