Question about Ovens
Whirlpool double oven GBD277PDB7 top oven fan has not worked for years,but oven worked all right and fan came if both ovens were running. Later if i used both ovens the PF code came on and they both shut down. after they cooled off I could use them again. lately even using just one oven, especially at heats higher than 350 causes the PF code to come on. had the repairman in he says it needs a new control board--funny thing is when he pulled the oven out of the hole and set it in the open both fans ran and the oven did not shut down. is it really the control board or possible a heat sensor fuse that is bad.
    President:
  • 949 Answers
I would more suspect a loose connection on the neutral circuit behind the ovens. I would image the technician did check this, but if not...
If all the power wires going to the ovens are intact and secure and the neutral is being supplied correctly he is correct about needing a new board.
Posted on May 27, 2010
    President:
  • 1,430 Answers
The problem is more likely a thermostat part # AP3885687 If you enter your model # at www.appliancehelponline.com it will be # 37 in the diagram.
Whirlpool oven rbd275 fan
Yes, you can do this. Oven cooling fan working at 120V
Nov 06, 2017 | Ovens
Whirlpool Gold model #GS395LEG oven control panel shows it is preheating, but you don't hear the click and the gas doesn't ignite. Ten minutes later, no heat!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 09, 2010 | Whirlpool RBD305PD Electric Double Oven
Whirlpool double oven has a loud fan when baking
There will be some noise from the fan, but it should not be excessive, if it is really loud, then this is an indication that the fan is failing, and should be replaced ASAP.
Mar 12, 2010 | Whirlpool RBD305PD Electric Double Oven
My double oven has stopped working, its only the large fan assisted oven which is producing no heat. The top oven/grill works okay. Is it an element problem ?
If the fan is working o/k, then you need to fit a new oven element, located at rear of oven behind removeable cover.
Please rate my solution.
Thanks.
Nov 18, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool built-in double oven model# RBD305PDB12
the humming sound is coming from the "squirrel cage" fan in the back of the unit, there may be some resonance vibration from the fan this issue should be addressed by a qualified service tech, the whole wall oven needs to be pulled out, i would have him check the fan.
Aug 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Ovens Logo
90 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
