Question about GE Profile JTP56 Electric Double Oven
Control panel doesn't work
The control panel doesn't work and F7 appears on the panel. What does F7 mean?
    President:
  • 1,430 Answers
F7 indicates either a stuck key or the main control has failed. Try depressing each button one at a time checking for a stuck key. If each one retracts I would replace the main control this is more likely the problem. There easy to replace. If you enter your model # at www.appliancehelponline.com you can get diagrams and illustrations of your specific model.
Posted on May 27, 2010
2 Suggested Answers
SOURCE: The oven doesn't work. F7 appears on the control panel.
Door lock release fault · Bent pull-rod for door latch
· Bad door latch solenoid
Posted on Feb 16, 2010
F7 dC
Well first of all you determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
This error code F7 means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC)......
Post comments for more help or information........
Good Luck!!
Mar 26, 2010 | GE Ovens
Feb 15, 2010 | Ovens
Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
Aug 28, 2009 | GE Profile Advantium 30" Built-In Single...
F7 code disconnected power with no luck
F7 stuck keypad
Aug 21, 2009 | GE JRS04 Electric Single Oven
The screen ready f7 and beeps every minute, What does it mean
F7
Jul 16, 2009 | GE JGRP17 Gas Single Oven
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
Oven shows F7 error problem with irritating beeping sound
F7 stuck keypad
May 13, 2009 | GE Profile JKP56 Electric Double Oven
Error code f7 zenn-air stove
F7 stuck keypad
Mar 22, 2009 | GE JGRP17 Gas Single Oven
Beeping and F7 when cleaning
F7 stuck keypad
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
Kenmore double-oven (electric)
F7 stuck keypad
Sep 22, 2008 | Kenmore 47722 / 47724 / 47729 Electric...
GE Profile JTP56 Electric Double Oven Logo
284 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
