Question about Sony PlayStation 2 (PS2) Console
Pcb no GH-006 mod chip diagram
Can i get chip Mars 11,Modbo 4 and mchip diagram for pcb no GH-006 used in SCPH-30004.
  • 21 Answers
The Modbo v4.0 is compatible with v5 to v16 and it is also compatible with the newly released SCPH-7700x & 7900x consoles. However for your SCPH-30004 I'd use a PS2 Duo 3 Gold. http://www.duomodchip.com/english/install.htm
Posted on Apr 23, 2008
SOURCE:
I have Sony play station 2 model SCPH 75004 which is failing to play PS1 DVD and CDs. I hear it requires a mod chip. Where can I get the mod chip and how is it installed to the PS2.
ruben, the PS1 is the only system created with the capability of adding a mod chip. When they first came out, the PS1Generation 1(PSX)could play burned games and DVD's. Sony discovered that it created an issue with the excessive wear of the cd drive, so they recalled the system. Then they re-released it and it couldn't play DVD's anymore. The PS2 could already play DVD so it has no mod chip function.
Dec 29, 2014 | Sony PlayStation 2
PS2 Modchip and Laser Fix installation Failure ...
I bough ps2 with cracked after 3-4 days not working dvds are not read.
sometime it's working some dvds..
so plz solve my problem...
May 28, 2012 | Sony PlayStation 2 Slimline Console
What is modding....how to install ext hard drive on the ps2 slim scph 90004
Modding is the process of putting a mod chip in the ps2 to read burned games and to hack games. I wouldn't recomend doing it because it is highly illegal.
Feb 27, 2011 | Sony PlayStation 2 (PS2) Console
Apple-75k mod-chip to be installed in playstation2
Ok I have a tutorial that is Wayyy to big to post here so I will provide a link, it is quite comprehensive I suggest you print it out.
http://www.brisbane-mods-brisbane-modchip-brisbane-australia.com/product-pages/ps2-apple75k-install-diagrams.htm
Feb 05, 2010 | Sony PlayStation 2 (PS2) Console
Can't play dual layered disk in playstation slim silver
I know, this is very annoying. Mine is SCPH-79001.
Just put in the game like you would any game (that would read) and you should hear a few ticks. Turn the ps2 horizontly with the front facing you. And whenever you hear a tick, just tap it against you knee, then you should hear it spinning.
My ps2 wouldn't read GH world tour or metallica, but know it works. Hope I helped
Jan 21, 2010 | Sony PlayStation 2 (PS2) Console
My PS2 won't load God of War 1 or 2 anymore
if it is a double layered game (backup...u need to burn it with layerbreak set on auto and on DAO if that don't work try incremental instead.
Also...if your system is modified with a chip...try and get a MArs pro chip instead...not modbo or matrix infinity....those chips have a hard time reading GOW
if your system isn't modified...try changing the laser...it could be getting weak
Jun 21, 2009 | Sony PlayStation 2 (PS2) Console
Hello, ir have my ps2 without video and audio, too can't turn off All fuses are ok, gh-070-32, now is without chip, before was a modbo 4 v1.99 Please help my, thank's
Sounds like its bricked. My guess is if it it had the modchip in it, and it was removed, it got fried, or was done incorrectly. If its not fried, try putting the chip back in, or get a soldering/wiring diagram and make sure it was returned back to its original condition.
Mar 16, 2009 | Sony PlayStation 2 Slimline Console
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
1,424 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
